vid after cam install
now what the hell do i do???also after i took it out there seemed to be chunks of this stuff all over the bolt ... then a big one came out the last time ... is this bad too??? i'm sick of this damn car!!
i know this can't be good
I feel for ya man, dont get too distressed, **** happens, you will get it up and running eventually. just be sure to take your time and do everything right next time, no shortcuts or band aid fixes.
To put a helicoil in only takes a few minutes.
To put a helicoil in only takes a few minutes.hey ur from vspot also ... i have no idea how helicoil would work ... do you think you could help me out sometime with it?
Exactly. I skipped responsed since this one, btw.
That bolt is grade 3, not that strong either. I had to helicoil -=Modified=-'s block on the lifter tray bolt. Works fine now. I'm not liking how aluminum threads..
Check this thread also. There are a bunch of responses in there about valve tick.. https://ls1tech.com/forums/showthrea...0&page=1&pp=20
-=Modified=-'s MS4 was ticking BAD too. We replaced the lifters and are in the slow process of replacing the oil pump pick up tube O ring and get a pushrod length checker in da mail to find out EXACTLY what length PR's we need. We went and tried three different length sizes and all of them tick. the 7.400's, 7.425's, and 7.375's (I believe, and were the WORST)...
have been quoting local shops around here to do the helicoil and they are saying around 200 if they take off the head and everything ...
Get the $20 Push Rod Length Checker and do it the right way.
What size HG again? You 'should' be good w/ the 7.4's unless you changed head gasket thickness. But measure to be sure.
