Parts needed for head swap?
1. 243 heads
2 GM MLS head gaskets (will the ones for the 2002 work, I only saw graphite for 98-01)
3. New head bolts (should I go with Fel-Pro or GM)
4. Intake Manifold gasket
5. Exhaust gaskets
6. Water pump gaskets.
I would go with GM bolts unless you want to go with the ARP bolts or studs.
I wouldn't think you'd need intake manifold gaskets or valve cover gaskets (I never replaced mine, but they were in good shape too), but I would definitely get the exhaust and water pump gaskets.
Good luck.
you will need new valve covers( center bolt) get off ebay or here!
new coil brackets get from dealer (be prepared to modify the bolt holes so your coil pack bolts will fit.)
get 2 water pump gaskets
get the arp bolts!! ten trillion times easier than the gm bolts... best way to explain the gm bolts is its like trying to fit a fat girl in spandex!!
arp you can torque and forget em... well worth the extra cash!!
shouldnt have to worry about the intake gaskets.
later aaron
later aaron
head gaskets.. mls got em for $50 off of here
thunder racing cam swap kit.. $78
2 water pump gaskets... (off of thunder) $2
valve cover gaskets... (oreillys) $16
arp head bolts.. $100 (off here)
misc crap (oil, arp moly lube, gasket sealer... ect) $50
coil brackets $30 (for both from dealer)
valve covers $50 (off here)
2 new oil sending units ( cause i broke mine twice!!!!) $60
new temp sending unit... again be careful with this one its hard to find at the dealer and costs $30
so grand total for stuff needed was $466 on top of the $600 mti heads i bought off here too!
