Need Solid cam with stock heads
I heard that if you installed a solid cam you will be have to adjust your rocker arms every several time , I wish to install solid cam but without adjusting my rocker arms every time .
So is their something will make me comfertable from that ? I mean is their something I can install it with the solid cam and its rocker arms without needing to adjust the rocker armes every time ??
Thanks in advance
Fahad ..
Bad idea....
Or you could just do the hyd. cam and pick up 30 rwhp.
Also, FMS has been building solid roller street cars for 2 years, the first of which used stock rockers and modified stock lifters! Matinence is not like it was 20 years ago. Granted you should be aware of you lash, but it's not going to need adjusting on a regular basis. In my experiece the sold rollers are just as streetable as hyd rollers, but have the potential for a little more matinence but not necessarily.
I mean. I want kit sold cam for street and daily drive.
Thanks.
Fahad..
Why not go with a hydraulic cam and ported heads? You'd have MORE power, it would be quieter, less expensive by a long shot and wouldn't require lash adjustment...EVER!
