heads and cam are in the car
lets see how it does
george
should've called me, i would've come by and maybe you'd have to install some other things twice <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> can't wait to hear that ASA cam <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Must sound good, huh! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
pushrods. the ls6 valves stems are longer and the cam I am using has a stock base circle. I have the heads bolted on and the rockers and pushrods
(7.35 length) installed. I crank the motor over and I got compression, but worried once I start the engine the lifters will pump up and prevent the valves from closing.
Thanks, jeremy
<strong>George, does the cam you used have a stock base circle? I am installing the cnc ls6 heads on my car and want to make sure I have the right length
Thanks, jeremy</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">you should have almost 2 turns of preload before you reach the 22fp tq that will tell you if the pushrods are right
george
