Cam Intake centerline any power difference?
The factory ground-in Intake Centerline (IC) is 110.
That gives it already 4 degrees advance if installed dot to dot. I think 4 degrees advance is more than enough, without installing an offset bushing or an adjustable crank gear and putting more advance in it than the regular 4 degrees it has built into it.
Ron,
In my case, I would actually need to install it 4 degrees retarded in order to get it "straight up" since it has 4 degrees advance already ground-in.
Would it perform better straight-up, or with 4 degrees total advance.... Don't really know.
I have heard, low rpm throttle response is better if the cam is advanced, but high rpm power is a little better with no advance.
Am I right?
I agree, but at least recently, all the folks that have degree'd in various LS1 Comp Cams have all stated that they came in within 1 degree of what was stated on the cam card.
I may be lazy, but thats why I am just going to put it in dot to dot with a new single Rollmaster chain set and leave it with the ground-in 4 degrees advance it came with.
Ron,
BTW, the Thunder Racing TR-220 is wrongly advertised on there web site as 220/220 .561"/.561"
It's actually 220/220 .553"/.553"
The LSA was to be 114, but actually was measured at 113.5 on Thunder's Cam Doctor (very close and no problem for me)
<small>[ October 14, 2002, 10:57 PM: Message edited by: Kimchee and Rice ]</small>
Cams that have an intake closing point of 40 degrees ABDC tend to make peak power around 6000 rpms. Close the intake around 42 degrees, they peak around 6100. 44 degrees, 6200 rpm power peak. 46 degrees, 6300 rpm power peak.
You can vary intake closing point by playing around with duration, LSA and ICL. For example:
TR 224/224 112LSA +4 cam has intake closing point of 40 degrees ABDC (6000 rpm peak).
TR 224/224 114LSA +4 cam has intake closing point of 42 degrees ABDC (6100 rpm peak)
TR 220/220 114LSA +0 cam has intake closing point of 44 degrees ABDC (6200 rpm peak)
2002 ZO6 204/218 117.5LSA -2.5 cam has intake closing point of 42 degrees ABDC (6100 rpm peak)
TR 230/224 111 LSA +2 cam has intake closing point of 44 degrees (6200 rpm peak)
MTI 209/216 116LSA +4 A1 cam has intake closing point of 36.5 degrees ABDC (5600 rpm peak)
Ideally, you want a cam that is size appropriately for an LS1 to be installed with 0 advance. For a 346, 224 duration seems to be ideal. Go bigger like to 236, you will benefit by advancing the cam. Go smaller like to 214, you will benefit by retarding the cam. The main reason is to get the intake closing point to a time where the engine can best use it. According to SAM, with a 224 cam, they lost about 5-7 rwhp and torque everywhere by advancing the cam 4 degrees and nearly the same by retarding it 4 degrees. But take a 214 cam and you will probably gain 5-7 rwhp and torque everywhere by retarding the cam 2-4 degrees. General rule of thumb. Too small a cam: retard. Too big: advance. Just right: go straight up. Not opinion, just proven dyno results by SAM.
<small>[ October 15, 2002, 07:31 PM: Message edited by: Patrick G ]</small>
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
