what do tou guys think of this cam
The cam is not a bad match to the heads, but so what?
With that much exhaust duration, it sounds like a nitrous grind.
Whose ported LS6 heads? What kinda car is it for?
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
the heads were done by Pete at "CNC"
NOT for nitrous
01 WS6 m6
compression will be around 11.3
this head/cam combo on a vette put down 430 rwhp running very rich with 10.7 compression
I figured with his extra drivetrain loss, my higher compression, tuning at cartek on dyno, my grott's (not sure what headers he had), and carsounds highest flowing cats (if I remember corectly the vette reused stock or not so great after market cats) 450 rwhp should be achievable
what do you guys think?
I posted because I've never seen anyone running this cam
thanx
NOT for nitrous
01 WS6 m6
thanx
I don't know what seat duration is (I have the specs from comp if it would be on there)
it has 0 degrees of advance ground in
by the way the valve sizes are 2.050/1.60
thanx guys
thanx guys
Yes seat duration should be on there if you wouldnt mind posting info, thanks. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Also if you can tell us duration at .200" lifter travel i can give you informed opinion of cam you chose.
<small>[ October 16, 2002, 06:10 PM: Message edited by: LS1derfull ]</small>
gross valve lift: .581/.588
duration at .006 tappet lift: 273/277
valve timing at .050: open close
intake 0 BTDC 44 ABDC
exaust 46 BBDC 2 ATDC
these specs are for the cam installed at 112 intake center line
duration at .050: 224/228
lobe lift: .3420/.3460
lobe seperation: 112.0
that's it
thanx John
that's it
thanx John
how does it compare to say a : XE-R? from what I've been reading, I think they're similar
if so how does the power compare to some of the ones you guys are running? say the 2 thunder cams.
thanx guys
thanx guys
I think that is an XE-R, don't know of any other Comp profiles like that. If you are ditching the cats and have free flowing exhaust, the extra exhaust duration isn't going to help.
I will have Grott headers, Carsounds highest flowing cats, SLP loud mouth. so your saying I would see no benefit without cats?
If I may chime in my XE-R lobe chart says the .200 lift duration is:
224 XE-R lobe is 146 @.200
228 XE-R lobe is 149 @.200
I hope this answers the questiion asked.
I am running a simular cam same lift duration except I have 2 degress ground in and katech said it is a custom Nitrous cam a with 114 LSA it rocks.
