To achieve 11:1:1 compression.....
<small>[ October 16, 2002, 02:14 AM: Message edited by: Alonzo ]</small>
<strong>Assuming stock displacement( 3.9x3.622 ) with milled 5.7L heads and stock thickness for gasket( 0.054" ); 10.5:1 compression. Using a 0.035" thick gasket would put you right at 11.0:1 compression. Hope this helps <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thank you very much I needed that.
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>Using a 0.035" thick gasket would put you right at 11.0:1 compression.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where do you get different thickness gaskets?
<strong>Where do you get different thickness gaskets?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Fel-Pro or Cosmetic should have something.
You said a stock disp. LS1 with .030" off the heads will yeild a 10.5 to 1 CR
How about .035" mill off the 5.7 heads with the stock head gaskets?
10.6 ?
Thanks,
Ron
BTW... Do you see any problems with a .035" flat mill of the heads? There must come a point where you run into problems with the sealing/alignment between the head and intake manifold.
<small>[ October 17, 2002, 05:13 PM: Message edited by: Kimchee and Rice ]</small>
<strong>[b]BTW... Do you see any problems with a .035" flat mill of the heads? There must come a point where you run into problems with the sealing/alignment between the head and intake manifold.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ron, we have gone .050" off the heads a few times without any problems. .035" would be fine.
BTW, ever get a micrometer on that 220 cam?
(base circle)
Ron,
<strong>How about .035" mill off the 5.7 heads with the stock head gaskets?
10.6 ?
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep. Assuming milling 0.035 will drop the chambers to 63.8cc from 67.3 and gaskets are 0.052" <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I am using GM head gaskets. Maybe I will look into the thinner gaskets. I would like to be closer to 11:1.
Mike
Josh
<strong>A buddy of mine is running LS1 5.7 heads milled to the point of trashing them, ~.064 or so and has no alignment problems with his LS6 intake.
Josh</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">WOW! That is alot.. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
In every other engine I am familiar with, that much would make alignment problems to the point that the intake just would not bolt to the heads. With a long duration cam, I would think your freind would have very serious piston/valve clearance problems.
It really suprises me that the LS1 can get by with that much of a flat mill.... Wow! There can't be much meat left on those heed surfaces.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Damian:
It really suprises me that the LS1 can get by with that much of a flat mill.... Wow! There can't be much meat left on those heed surfaces.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">His setup is quite unique compaired to what most people are used to seeing on the board. He has valve reliefs cut in the pistons though, so no problems there. The intake bolts up fine....
Josh
