Stroker cam ????
Old Oct 16, 2002 | 07:37 PM
Slammed Vette's Avatar
Default Stroker cam ????
What would be a good BIG cam for a 382 stroker(not an all-bore)???I do mean BIG!!!!!TIA
<small>[ October 16, 2002, 07:40 PM: Message edited by: Slammed Vette ]</small>
Old Oct 16, 2002 | 09:29 PM
Redline-Motorsports's Avatar
Default Re: Stroker cam ????
Bigger isn't always better! What kind of heads are you using? How much compression will you have? Auto or stick?
I am finishing up a 418 motor that is using a .644/.630 with a 238/244 duration on a 112 LCA. A cam like that would kill a 382.
Trying calling CompCams tech line and see what they say. Give us some more data on your setup!
Old Oct 17, 2002 | 04:17 PM
Bigger isn't always better! What kind of heads are you using?I have stage III heads now and I'm contiplating going to a stroker with the or a set of 2.05-1.60 How much compression will you have?probably around 10.8-11.0 Auto or stick? A4
I have a 226/234 cam in it now and it runs great after a lil LS1Edit.So tuning will not be a problem
Old Oct 17, 2002 | 06:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd stay above 230 duration for both the intake and the exhaust Hampton.
Single pattern will idle better.
Old Oct 17, 2002 | 08:10 PM
I was thinking maybe the Raging 230/230 .592/.592 110 or maybe something in the 234/234 range.
