Next logical step up in cam???
I was thinking something like a 226/226 - 114lsa.
Would it be worth the swap? Or should I go with a little more duration?
Joe
The dyno here in town is still not up and running so I haven't got any numbers yet but I did trap at 116.75 MPH (12.43 w/1.9 60ft.) at the track other day with a slightly slipping clutch which proves the car is making some good HP. I am just throwing around the idea of trying a different cam but may leave the B1 in.
Leave the B1 alone,Its a good cam...
Most properly setup MTI S2/B1 setups run 118/121
Your alittle down on power.Joes right,u need to EDIT your setup for optimal power.
JS
