Katech pump idle pressure?
Old Oct 17, 2002 | 09:41 PM
BLUEBYU's Avatar
Default Katech pump idle pressure?
I just installed the Katech pump and now see idle pressures varying between 20 to 38 psi. My stocker was running steady at 42ish at idle. BTW, I had good pressure with that pump, but thought I would get some peace of mind with the whole "failing pump" issue. Under increased rpm's the new pump seems normal. What are you guys seeing at idle? As a note, I did overfill a bit on the last oil change (when I did the pump swap) but if any thing that should raise the pressure <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> . I actually see a fluctuation at idle that is my main concern. I do have the TR224 cam...but again I had no fluctuation before.
Old Oct 17, 2002 | 10:15 PM
BLUEBYU's Avatar
Default Re: Katech pump idle pressure?
ttt
Old Oct 17, 2002 | 11:31 PM
glhs379's Avatar
I am looking into that pump as well as their timing chain, I would be interested in getting some response also about your pressure reading?
Old Oct 18, 2002 | 07:52 AM
Fireball's Avatar
mine is at 30-40 psi at warm idle (depending on oil temperature) I believe since they are ported to fix the casting flash problem but are not shimmed up that a slight loss of idle pressure can happen. I pull a good 60-70 psi at WOT
Old Oct 18, 2002 | 07:53 AM
BLUEBYU's Avatar
ttt
Old Oct 18, 2002 | 08:32 AM
CamM's Avatar
My Katech oil pump is slightly above 40 psi at idle and above 60 psi at WOT.
I use Red Line 10W30, if that matters. I just had my pump installed about 3 weeks ago.
Old Oct 18, 2002 | 10:22 AM
iowass98's Avatar
my runs the same as camM with 10 w 30 redline
Old Oct 18, 2002 | 11:26 AM
5150Z28's Avatar
I'm thinking about picking up a Katech oil pump and this is some good info to know. I also use Redline 10w30 and it's nice to know approximately the oil pressure that I should see when I install it.
Old Oct 18, 2002 | 11:33 AM
HOSS99's Avatar
My Katech pump runs between 30-40psi at idle,
and between 60-70 at wot.
Old Oct 18, 2002 | 11:56 AM
StevieZ's Avatar
Mine ran slightly lower than my stock pump with about 38 psi at hot idle and 58 psi at WOT. That was until I busted my pressure sending unit while installing my LS6 intake. I installed a new sending unit and it instantly read 45 to 50psi at warm idle and 70 to 75 psi at WOT. Don't trust your readout if you have an old sending unit.
PS: I ran some Royal Purple racing # 11 (which is like a 5W20) for a while in aug. and my pressure still was 40+psi at warm idle and 65ish psi at WOT
<small>[ October 18, 2002, 12:08 PM: Message edited by: StevieZ ]</small>
Old Oct 18, 2002 | 01:25 PM
BLUEBYU's Avatar
Does anyone see gauge fluctuation at idle???
Old Oct 18, 2002 | 02:22 PM
DenzSS's Avatar
How much of a guage fluctuation are you seeing? Is it bouncing back and forth a bit?
Old Oct 18, 2002 | 02:31 PM
Hawk's Avatar
No gauge fluctuation Good pressure If yo get the JWIS timeing chain Get the Cloyes adj Gear set.
BLUEBYU's Avatar
It is moving about an 1/8" up and down with the lope of the engine idle.
Old Oct 19, 2002 | 06:07 AM
HOSS99's Avatar
No Fluctuation at idle, Here.
Old Oct 19, 2002 | 06:09 AM
HOSS99's Avatar
Old Oct 19, 2002 | 07:25 AM
EVIL's Avatar
i had the same thoughts. at idle mine drops down to almost 20 and i am not sure about WOT. we broke the wire on my sender on my motor install, and soldered it so i am thinking that it may be a problem. i guess it has good pressure otherwise it would have let go by now.
