Valve train setup with F1 cam...
with a 591 lift and milled heads your valves will probably hit the pistons. You better clay it.
<small>[ October 21, 2002, 12:42 PM: Message edited by: 30thta436 ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 30thta436:
<strong>with a 591 lift and milled heads your valves will probably hit the pistons. You better clay it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">what is meant by claying it? Just putting some playdough or something on the piston, laying the heads ontop w/out torqueing it down and manually rotating the crank?
