two things
Old Oct 25, 2002 | 12:01 AM
Slowverado's Avatar
Default two things
if you have a 5.3 and put a 6.0 crank in it...what do you come up with and what other mods would have to go along with that conversion. how do you find cubic inches but borexstroke...what is the formula?
Old Oct 25, 2002 | 12:54 AM
Brandon98TA's Avatar
Default Re: two things
I'm pretty sure that the 5.3, 5.7, and 6.0L all use the same crank just different bore. 5.3 has a 3.779" bore, 5.7 has a 3.89", and the 6.0 has a 4.001" bore; all use the 3.622" crank. The formula for cubic inches is Cylinder area x Stroke length x 8. (pi x r(1/2 of the bore size))^2 x stroke x 8.
http://www.aera.org/Tech/cube_calc.html
That site will do it for you, just plug in the bore, stroke, and # cylinders. To get liters, divide by 61(approximate). Hope that helps.
Brandon.
