**Just did my Cam Swap...possible problem**
woah woah...with an ls6 pump your at 25 at idle??? I have an ls6 ported pump here that i'm installing monday. didn't wanna spend the 500 bucks to have someone install it, but better safe than sorry.
My 98 trans am convertible with 39,000 miles and also with the stock oil pump, however, idles @ 50 psi on cold start up and then drops down to around 20 -30 psi when hot. The needle jumps up to 60 with the higher rpm's so it seems fine, but it does not act like my 99.
Internal engine clearences, temp, oil, filter etc. will all have an effect on it.
You are fine.
Have fun with your car.
We replaced the oil pickup tube O ring w/ a slightly thicker GM one. That solved a LOT! The oil pressure sits FIRM at 60psi now at idle. It idles at about 950rpm. I think that's what his tune is set for at least.
Something to consider if you have not already figured the problem out. The smaller O ring could be slightly leaking, causing aeration of the oil being pumped. Also could have been causing out valve train knock.
