valvetrain noise after wot?
the car is not stock , i have a blower, iron block, comp cams cam and lifters and crane 1.8 rockers.
what could be causing this? could it be a collapsed lifter? should i switch to heavier oil ( currently using synth. 10w-30)?
or do i have to replace the lifters?( please tell me i don't have to cause i just did 2k miles ago)
what lifters would be best? ( i had cranes and the suck, and i have comps right now, not the type-r)
<small>[ October 26, 2002, 09:01 PM: Message edited by: jason hamilton ]</small>
You may have to put up with some valvetrain noise with some parts. I say try the Comp Magnum R lifters.
Good luck and let us know what you find.
could it be a collapsed lifter? wrong preload ( lossening rocker)??
someone please help <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
if it is a collapsed lifter , which should i use?
i already used cranes ( used for 2 weeks ) and tossed them out cause of exssessive valvetrain noise at all times, and now i'm using comp cam's lifters ( non magnum-R).
