new cam start up????
Old Mar 30, 2007 | 12:23 AM
Camaros710102's Avatar
well I got back in there and backed all of the adjusting nuts back off and started over. I also called and talked with Vinci this morning and went over the "zero Lash" with them. I thought originally when reading the instructions that there was to be no movement at all and yes I admit that I over tightened them with my fingers. Vinci did say that I would be better off leaving them looose rather than tight when starting the 1/4 turns. I cranked over the motor and compression test and it sounds like a motor is suppose to sound when cranking over. I'll put the covers and coils back on tomorrow and give her another try. It's be a long day...thanks for the help and I am planning on recordng the start up and getting it on here.
Old Mar 30, 2007 | 06:56 PM
mrr23's Avatar
that's usually what it is, most of the time. glad they were able to walk you through the procedure.
