help me build my motor.
stock bore
diamond pistons and rings, eagle connecting rods,
need help finding a crank that can handle some power or should i just use stock one??
also, i wanna do a custom grind for nitrous.
thinking of somehting like a 23x,23x 56x,57x on a 114 lsa, (need some help with that to) most likely a custom grind cam, thinking of doing roller rockers also, so i may go way bigger on the cam let me know what yall think. this is gonna be a nitrous motor.
there teally is no limit on the horse power stock crank and rods will hold with after market bolts that is. The limit on stock parts is rpm stock components if not taken over 6800 alot will hold up fine. Just get good pistons and good rings and rod bolts. my .02!
I run a 114 lobe but I have a blower, you want more like a 113 that is a little more agressive. The stock crank is fine but get it keyed and also get the crank Nitrided (hardened)
