Double help needed
Old Mar 30, 2007 | 02:32 AM
LSGunZ28's Avatar
Default Double help needed
after this question
first and foremost, I have been making a few threads here and thre, sorry but Im so undecided as to what I should do.
I also need reccomendations on what gearing to get, along with what cam to get.
firstly, how difficult is it going to be to do a head/cam package, I understand my headers, intake manifold, etc will ned to come off. But this may be a dumb question, but will I need to drop my engine to do a head and cam package install?
I am looking for something as streetable with a 224/224 or a 228/228 cam, but want a higher peak HP. I was thinking something in the 230 range, but not as big as a 238. I will have a
If I go with 3.73s I was thinking a 230 cam with 112 LSA or with 3.90 gears 236 cam with 111 LSA... I think those would be somewhat streetable.
Also if the head and cam package is that hard to do ( dropping the engine) then am I better off rebuilding to a 383 and going with even a bigger cam?
I was looking to spend 2 grand, but if the rebuilding is a better idea I am willing to wait a few more months and spnd 6 grand. or even better yet wait a year and spend 12 grand o a new L92 block... inwhich that case what would be a good streetable cam?
I doubt this will get many answers since I have so many minor questions and its basically all preference, but I dont wanna make a mistake.
Some key points
I have all supporting mods: Lts, ory ( soon tsp true duals) and Lm1/dynomax bullet, lid and cold air induction ( havent ported T/b or MAf yet) also no tune yet.
engine has 85,000 miles +/- a few
a 2002 Z28, pewter, m6
currently rebuilding my transmission
aluminum flywheel
and ls7 clutch
going with anywhere from 3.56 - 3.90 gear range, FOrd 9" probably a Moser, leaning towards tru trac. also have almosta full suspension on the car.
if easy to do, going for my stock 346, with some ls6 heads and a 232 cam(example)
if not an easy task, may wait a few more months and do a 383 with a bigger cam.
or if that isnt worth it, I will wait over a year ( dont really wanna wait this long at all) and do a l92 with, yet even a bigger cam
looking for somewhat streetable, a daily driver, but due to the lack of low end, that is why I am choosing 3.90s, but if a 232 will be reasonable I will stick to 3.73s or 3.56s.
If anyone can help , please.
Old Mar 30, 2007 | 03:07 AM
LSGunZ28's Avatar
to help make myself a bit more clear ( hopefull, that is my goal) I will provide a couple of examples of what I am wanting to do...
I am thinking of doing a head/cam package first. Even if it will take a lot of work...A cam in the range of 232 - 236 duration 112 or 111 LSA for a bit higher RPM torque than stock with 3.73s trutrac....
3.73s because in over a year I will leave my drivetrain, aluminum flywheel, 3.73 trutrac moser and aluminum 1200 Hp rated driveshaft..but upgrade my powerplant to a L92 and go with a larger cam. the 3.73s should pull just fine, even if I go with a rather large cam, since It has a 4.0 stroke it will make plenty of low end torque, but I cant have any overlap past 110 LSA, since the stroker will not be a good choice with it.
what cam would be good for a DD, makes a lot of torque, but high Horsepower, so I want midrange and top end, but dont want to completely lose power during cruising..
Also I drag race and Track race my car, besides it being a DD.
Old Mar 30, 2007 | 06:12 AM
brad8266's Avatar
A head and cam swap is not very difficult, with help from a friend it should only take a weekend to do all saturday and sunday.
Going with a built engine is always a good thing IMO, so if you have the $$ to do it then do everything at once. if you dont have enough right now for the engine but you can get the heads/cam then go for it.
I suggest you at least buy a ported TB and a LS6 intake for the swap too.
I have a 232/236 cam and it is completely street friendly especially since I have a higher compression motor. Heres my graph so you can see how much power a cam like this can make and where it makes power at, made lots of torque in the low RPM's.
Old Mar 30, 2007 | 10:00 PM
LSGunZ28's Avatar
sounds good.
In that case Id want to do a head and cam package with my 85,000 mile engine an dby the time I hit 100K - 110 K, I will get a brand new engine as well as rebuild my LS1 and save it as a spare.
What gears are you running with your cam an dhow much a difference did you see after the cam change? what heads are you running?
also I already have a LS6 intake ( its a 2002)
Old Mar 30, 2007 | 10:14 PM
brad8266's Avatar
Originally Posted by LSGunZ28
sounds good.
Stock 3.42 gears, i did a forged engine/heads/cam all at the same time so i dont know how much the cam was worth. TEA stage 3 heads.
Old Mar 31, 2007 | 12:31 AM
LSGunZ28's Avatar
So I should be fine if I go with 3.73s...
would a stage ls6 head work well, or should I go with what you had?
Old Apr 1, 2007 | 07:45 PM
LSGunZ28's Avatar
bump!
Old Apr 1, 2007 | 07:49 PM
brad8266's Avatar
3.73 will work fine, and a worked LS6 set of heads would do good.
Old Apr 1, 2007 | 08:36 PM
LSGunZ28's Avatar
So Brad, lets say I get a 232/236 cam or a cam of similar characteristics...as well as a set of LS6 heads, along with new pushrods, springs, lifters, retainers, etc.... That being said
with a Ford 9", aluminum driveshaft, Aluminum flywheel, all boltons, inluding a 25% u/d pulley, LTs, trueduals ( soon to have) but LM1 for now and no cats, and a lid. also a tune.. I should be seeing similar numbers as you? perhaps a bit lower, since I am not sure how high your CR is..
Im probably gonna get them from Texas Speed.
Old Apr 1, 2007 | 09:16 PM
LSGunZ28's Avatar
where did you get that cam from and what are all your boltons if you please?
Im looking for these 2 cams similar to the one you listed, what LSA are you running @?
http://www.texas-speed.com/shop/item...d=669&catid=44
http://www.texas-speed.com/shop/item...d=169&catid=44
Old Apr 2, 2007 | 04:33 AM
mcamarols1's Avatar
mods in the sig, i still have to install my ported TB, and underdrive pulley, power was made through z06 wheels, and 12bolt w/ 3.73s
u cant go wrong w/ either cam, call TSP up they'll point u in the right direction
Old Apr 2, 2007 | 06:54 AM
brad8266's Avatar
I cant say exactly how much power you will make, all setups are different. My heads are 57cc, compression is in the 11.8 area. If you go wioth a 9" it will eat a little of your power, just a few HP.
Old Apr 2, 2007 | 06:55 AM
brad8266's Avatar
Its a comp grind on an XE lobe. Mines a 112 LSA.
I like the 233/239 and the TQV3, both good cams.
Old Apr 2, 2007 | 07:02 PM
LSGunZ28's Avatar
what kind of flywheel do you have a steel? also what driveshaft?
also can you link me to those heads? chat CR would they leave you at?
so 406 RWHP with all boltons excluding a ported TB and underdrive pulley as well as a 12 bolt with 3.73s
Also what dynamometer was it dynoed on?
thanks.
Old Apr 2, 2007 | 07:04 PM
LSGunZ28's Avatar
thanks for the input..
but what bolt ons do you have?!?! , I didnt see if you ever mentioned them...
Old Apr 2, 2007 | 07:31 PM
brad8266's Avatar
pacesetter headers, custom out the back duals, unported FAST 90, Nick Williams 90mm TB, March ud pulley, slp lid, MAfless, 42lb injectors, walbro fuel pump. I may be missing one or 2 but thats pretty much it. I have about all boltons except an electric water pump and cutouts.
Old Apr 3, 2007 | 12:46 AM
LSGunZ28's Avatar
cool thanks a lot
so you are on a steel flywheel? and a stock 10 bolt?
LSGunZ28's Avatar
cool thanks a lot.
so you are on a steel flywheel and a stock 10 bolt?
Old Apr 3, 2007 | 06:28 AM
brad8266's Avatar
cool thanks a lot.
yeah i use a SPEC billet stell flywheel and a stock 10 bolt.
Old Apr 3, 2007 | 08:59 PM
LSGunZ28's Avatar
Alright thanks a lot, anyone else besides Brad?
