How Much to Mill Safely with this Cam
How much to mill safely (PTV) a stock LS1 with this Comp Camshaft without flycutting, using stock MLS gasket:
54-444-11 (224/230 .581/.592 114), Spec is for Cam installed at 112 ICL. IVO:25, IVC:69.
Is .040 or .030 safe enough.
Originally Posted by bluecamaroz28
I got 11.11/8.54.
Originally Posted by brad8266
Whats the thickness of the MLS gasket? I saw stock and i plugged in .052 Either way isnt going to make a big difference anyway.
Cylinder Head Volume (cc): 62
Piston Head Volume (cc): -1
Gasket Bore (in.): 3.910
Cylinder Bore Diameter (in.): 3.898
Deck Clearance (in.): -.008
Stroke (in.): 3.622
Rod Length (in.): 6.098
Intake Closing Point (degrees)
ABDC @ 0.050 lift plus 15 degrees: 69,
I just tried and added 15+69 and got 7.34 for DCR. SCR remained same 11.11. So, which one is right?
