thread lock on rocker bolts?
Old Mar 30, 2007 | 02:08 PM
rickkym's Avatar
Default thread lock on rocker bolts?
A friend just did a cam in his corvette and didn't use thread lock on the rocker arm bolts. He just torqued the bolts to 22lbs or whatever.
Was he supposed to use thread lock? If so should he fix this immediately? How big a deal is it?
Thanks!!
Old Mar 30, 2007 | 02:17 PM
Ferocity02's Avatar
Most people do, but many don't and have no issues, so don't worry about it.
Old Mar 30, 2007 | 02:38 PM
blkbird's Avatar
X2....
Old Mar 30, 2007 | 03:03 PM
Tootall's Avatar
If you don't, it'll all depend on how you drive it. More or less, it will burn "some" oil.
Old Mar 30, 2007 | 03:42 PM
5.3LJimmy's Avatar
It would only burn oil if it has heads ported far enough that the rocker hole is visible thru the intake runner. It will not burn oil w/ stock heads. I personally never use loctite on mine, the bastards are hard enough to take of w/o it.
Old Mar 30, 2007 | 05:27 PM
ROCNDAV's Avatar
Is it thread lock or the white pipe dope stuff (teflon?) that should be used
Old Mar 30, 2007 | 05:55 PM
rickkym's Avatar
They're stock heads so sounds like no worries.
You guys kickass!!! Thanks!!!!
Old Mar 30, 2007 | 06:52 PM
Tootall's Avatar
thread lock . . . . means "lock tite" . . it's a red or blue liquid that hardens
The tape is only for pipe threads
