OIL question PATMAN!...what's the difference...?
which one is thicker/thinner?....which is better in cold/hot whether?........and what is 0W-30?..I saw it at Wal-Mart...it was a Mobil 1?... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> ....
<small>[ November 06, 2002, 01:38 PM: Message edited by: Colonel ]</small>
Charlie.
As another note, not all 5w30s and 10w30s are created equal either, to add more confusion. In order to be a 30wt oil, it has to have a viscosity of between 9.3 cst at 100c and 12.5 cst at 100c. So one oil brand could be at the thicker end and be 12.0, while another could be on the thin end and be a 9.5. That's why it pays to look up the technical specs on an oil before deciding which one to run.
I've been using 0w-30 in my LS1 lately but due to what Pat has said I will switch to 10w-30 year round next time for sure. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
As long as you're not driving in -30F temps or colder, you would be safe with Mobil 1 10w30. It has a pour point of -49F, which means it's borderline pumping temp is about 20F higher (or -29F)
http://www.bobistheoilguy.com/motoroil.html#viscosity
Or is it still better for cold start up, in any kind of colder weather, to still go with the thinner weights, VII issues notwithstanding?
I just want the best combo of cold start up (a major role in engine wear) and horsepower benefits/fuel economy along with 'hot oil' engine wear as well. Thanks.
