intake problems
Old Nov 8, 2002 | 01:50 AM
Nice4thgenZ's Avatar
Default intake problems
i installed a holley ls6 intake on a 99 ws6. i have double checked everything and cannot figure out the problem. when u start the car the idle goes up to 2500. it just sits there. we have checked for vac. leaks and found nothing....any help would be great...thanks
Old Nov 8, 2002 | 05:56 AM
nbm00ws6's Avatar
Default Re: intake problems
Check to make sure that the throttle blade is closing all the way, if it's not then adjust the cable.
Tom <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Nov 8, 2002 | 10:35 AM
we did, cause that is what i thought it was. its so weird cause the car drives great and doesnt sound like it has any intake leaks. but the car wont idle down
<small>[ November 08, 2002, 10:37 AM: Message edited by: Nice4thgenZ ]</small>
Old Nov 8, 2002 | 01:30 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sure sounds like a vacuum leak to me.
tonite i am going to start by looking again at the tb, then i will look in to the maf. btu the thing i am worried about is that there is a plate that you can remove on the bottom of the intake to do more porting to it. well that plate has a gasket and that might be leaking but i dont really think it is. if all else fails i will pull it back off and reseal the inspection plate.
Old Nov 8, 2002 | 01:36 PM
LS1Tech Co-Founder
Make sure the IAC is plugged in.
Did you try to spray carb cleaner around the bottom of the intake to see if the motor R's up?
Old Nov 8, 2002 | 01:37 PM
silverbullittSS's Avatar
try plugging the idle air control inlet with your finger or a rag and the car should alomst die. if it really does not change any the u got a vacuum leak some where. if plugging it and the car dies then the idle air control motor is not working properly.
Old Nov 11, 2002 | 05:27 PM
MIKET@CENTERFORCE's Avatar
I would look very seriously at the bootom plate on the manifold. I have had trouble with it being to thin and flexing/bending between the bolts. i built a thicker plate and sealed it without the gasket (motorcycle case sealer), all is well now.
