all-bore 382ci vs 383 stroke
Old Nov 13, 2002 | 09:47 AM
oOoLy's Avatar
Default all-bore 382ci vs 383 stroke
1)What is the best engine all-bore 382ci or 383 stroke for street racing ?
2)What is the difference between all-bore 382ci and 383 stroke in the price ?
Thank you
Adnan
Old Nov 13, 2002 | 01:05 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Re: all-bore 382ci vs 383 stroke
Most 4.0" cranks are going from $1900ish to about $2300ish.
All the resleeved block I have found, 4.125" bore, go anywhere from $2600ish to $4500.
There are a couple of things to consider for each.
Going with the Stroker, at a mininum new 6.125" connecting rods and pistons will be needed; from $550 and up for the pistons and $600ish and up for the rods..
With a block, you can keep the connecting rods, you will need new psistons; $600 and up.
The Stroker will make more low end torque and the block will produce more upper end horsepower. For the street, I would recommend the stroker.
Just my $0.02 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 13, 2002 | 01:34 PM
JPR's Avatar
JPR
We just recieved our 4-5 week backordered Cometic gaskets right before I left for vacation, we will have our 382 all bore assembled and on the dyno shortly, it will be a very interesting stroke vs bore comparison! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
Joe.
Old Nov 13, 2002 | 02:20 PM
DONAIMIAN's Avatar
stroke it <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Nov 13, 2002 | 05:21 PM
theblur98ss's Avatar
I was in the same boat and decided to just buy the bored block and do both. I figure to do it once and be over with it.
Old Nov 13, 2002 | 06:43 PM
zdawg28's Avatar
Go with the Stroker the extra torque will help you off the line more.
Old Nov 13, 2002 | 11:38 PM
Carlitos's Avatar
Here's another point of view:
If you're on the street, just how much low end torque do you need? Chances are you won't be running the tires necessary (slicks) to actually use that low end torque. The stock 346 has plenty of low end torque to spin some drag radials off the line. Once you get off the line you'll be using your top end more. I would suggest the all bore if you're looking for more street performance. Just my .02.
'Los
Old Nov 14, 2002 | 12:50 AM
oOoLy's Avatar
ttt
Old Nov 14, 2002 | 05:31 AM
oOoLy's Avatar
Thank you all for your reply...... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Adnan
Old Nov 14, 2002 | 10:24 AM
Hardtop's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Carlitos:
<strong>Here's another point of view:
'Los</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats an excellent point. Hooking a 346 car with radials and gear on the street is hard enough. A stroker would be tougher to hook.
Bruce
