Valve Train Question
Old Apr 4, 2007 | 08:28 PM
TORCHD 02 TA's Avatar
Default Valve Train Question
I swapped my stock cam to a TSP custom grind. Got the longer PRs (7.425) and got TI retainers, seats and seals. already the car is known for the 'tick' but mine seems to be a bit louder. can really hear it next a driving car or building.
Please no one say switch to GC 0W30 Syn. Did that when i had the stock cam. Man the car was louder than ever. Switched it back to Mobil 1 5W30.....
So i thik that my lifters are going bad????
any ideas?
Old Apr 4, 2007 | 08:34 PM
brad8266's Avatar
Probably should have used a set of 7.450 PR's. Swapping to a better lifter is always better when doing a cam since the stockers arent meant for the lifts and ramps of aftermarket cams. Its just too bad you have to pull the heads to do it.
Old Apr 4, 2007 | 10:54 PM
mvvette97's Avatar
I also run the 7.425 pushrods and it still makes alot of noise. I put new lifters in thinking it would fix the tick but it didn't. I guess if it blows then i will go to plan B
Old Apr 5, 2007 | 05:01 AM
85ta383's Avatar
mine is loud as hell too with ls7's and 7.425, harland reworked rockers... i think i need longer ones... probably should have used a pushrod checker but i didnt... at least its on both sides so it doesnt sound like a rod knock! freakin annoying! my tuner said... " i dont even hear a tick" i said thats all i hear and i have true duels.
Old Apr 5, 2007 | 12:52 PM
Yea Brad i did not know that they mad 7.450 PRs.... thought i would be ok woth the 7.425..
Thanks
Old Apr 5, 2007 | 01:00 PM
BAD2000TA's Avatar
I'm going through the same thing. I installed MTI's Stealth II cam that has the XE-R lobes. MTI recommended 7.40 length push-rods, as did Predator-Z. Well, it runs, but I hate the ticking. Brought the car up to MTI. They said it's louder than most they've done, but then said I needed 7.35 inch push-rods and to shim the rockers? WHAT? That made no sense, but I didn't feel like trying to argue my point.
Per the push-rod length calculator on one of the sticky threads, my optimal push-rod length should be 7.415". But, before I order new 7.425" push-rods, I ordered a push-rod length checker from Summit. $20 for my piece of mind. I'd recommend getting the checker and knowing for sure what you actually need, rather than guessing. Good luck!!!
Brian
Old Apr 5, 2007 | 01:09 PM
cowboysfan's Avatar
I'm running 7.425 thats what it took to quiet down my "sewing machine". did use the p-rod checker. and if you didn't replace lifters, maybe you need too.
Old Apr 5, 2007 | 03:25 PM
yup that is what i got, the 'sewing machine' sound
Old Apr 5, 2007 | 09:42 PM
01redws6ta's Avatar
Hey Torchd 02 TA, are you saying that you made 73 RWHP and 35 RWTQ with that cam swap alone? I was debating on getting that exact same cam. It would be nice to know what the base circle measurement is on it so I could put it into the pushrod calculator...would you happen to have that? BTW, did you get your tuning issues taken care of?
Old Apr 6, 2007 | 07:13 AM
yup that was jsut swapping the cam, ls6 oil pump, 160 T-stat and ASP UDP. That was it and i gained 73/35 Not too shabby eh?
Yup i think i got the tuning all worked out finally. Except bucks a little bit, and my car has no warm start. But all in all I AM VERY HAPPY NOW!!!!!
Old Apr 6, 2007 | 07:19 AM
brad8266's Avatar
It would be nice to know what the base circle measurement is on it so I could put it into the pushrod calculator...would you happen to have that? ?
XE-R lobes are 1.440
