View Poll Results: How many miles is too many when thinking about a cam swap?
>50k
5.81%
>75k
14.19%
>100k
27.10%
>125k
52.90%
Voters: 155. You may not vote on this poll
Highest mileage for cam swap *POLL*
Old Apr 5, 2007 | 07:44 PM
hpjunky98's Avatar
Ya Ive been wondering the same thing. I have 144k on mine, but ive never had any problems with the motor itself, and I change the oil every 3,000 miles. Ive never seen somone on this forum regret doing a cam swap in a high milage car...
Old Apr 7, 2007 | 01:19 AM
00slowredz's Avatar
i put 75k before reading all of these posts but damn! you guys put cams in some pretty high mile ls1's so i think i have changed my mind lol
Old Apr 7, 2007 | 10:05 AM
PREDATOR-Z's Avatar
Originally Posted by GR33N GoblinM6
im at 114k and im doing a cam swap in 3 weeks.. my oil pressure is always 55 at idle.. 65 under throttle.. always running good.. not a daily driver anymore either..
but im not going aggressive with the cam... looking in the 220-224 range..with a lift no greater than .570.. because its not what i need
It is not lift or duration that will be an issue but rpm.
Keep it under 6300 and you shouldn't have issues.
Old Apr 7, 2007 | 10:06 AM
PREDATOR-Z's Avatar
Only the ones that spun rod bearings
Old Apr 7, 2007 | 12:49 PM
SSwanner's Avatar
what would a cam swap have to do with spinning a rod bearing?
Old Apr 8, 2007 | 06:42 PM
juicedSS's Avatar
i put a cam cam in my black one at 145k and it has 156k now
Old Apr 8, 2007 | 07:28 PM
WONCAMARO's Avatar
put to large of a cam which is designed for high rpm redline and you will be tempted to run it that high. That will spin a rod bearing on even a lower mileage motor. I have 104k on my trans am. Oil pressure is about 30 psi at 600 rpm idle and about 60 psi under a load. I would not even think twice about a cam swap. Just dont get **** in the motor when you do the swap and get a good look at those cam bearings. Cam bearings usually don't go out too easily, but when they are worn and you slap a new cam in, it can eat em up. I found that out just in time to save the motor in my last high mile cammed car.
Old Apr 8, 2007 | 10:05 PM
Medic/Z28's Avatar
Did my H&C swap two weeks ago with 156,000 miles on the motor. When they took it apart she was clean and in good shape. I replaced EVERYTHING they took off though and put in all new parts. She runs good and stronger than ever. I've always taken care of my cars though. Never redline her or pushed her to the limits.
Old Apr 8, 2007 | 10:29 PM
SSNISTR's Avatar
Shoulda bought a Civic then.
Or you're lieing lol.
Old Apr 9, 2007 | 01:18 AM
Asmodeus's Avatar
getting a H/C/I swap as I type this, 97k on clock.
also changing lifters, oil pump, timing chain, and of course pushrods.
Old Apr 10, 2007 | 01:10 PM
8tsixt's Avatar
115k, ms3 and heads going on.
Old Apr 11, 2007 | 12:06 AM
  #32
GT Griller's Avatar
My buddy did the TR224 at 155k then at 158k swapped it for the MS4 and hes been spraying since about 120k.
Old Apr 11, 2007 | 12:07 AM
  #33
98mysticZ's Avatar
124k just did an ms4 swap and spaying a 150 shot ............4th set of rear end gears
Old May 3, 2007 | 09:57 AM
  #34
slt200mph's Avatar
The third one just went in this time it was at 130,000 miles..
Old May 3, 2007 | 12:50 PM
  #35
red02Hawk's Avatar
164,000 on her now, but when i pulled the heads off @163K the cylinder bores still had the factory cross-hatching in them!!
Old May 5, 2007 | 09:54 AM
  #36
CoreyZ/28's Avatar
~130k for me
Old May 19, 2007 | 03:12 PM
  #37
2 SSlow's Avatar
mileage doesn't matter... I put my cam in at 60k. One year later it blew up at 92k. Every motor is different, you just need to determine the history of your motor, and any issues it might have. Don't over rev it whatever you do.
Old May 20, 2007 | 02:21 AM
  #38
cowboysfan's Avatar
I voted 100k but, I see now most think 125k+ . either way I think thats high but, if I did w/ over 100k I wouldn't go big cam, maybe something like 220/220 114lsa .02
Old May 20, 2007 | 08:40 PM
  #39
ALL UC2's Avatar
i did one at 114k. did fine. i would do an oil pump, springs and if you plan on spinning it any higher i would go with rod bolts too. but, to answer your question i would say about 250k is pushing it lol, i would probally try it even then.
Old May 20, 2007 | 09:31 PM
  #40
customz28's Avatar
cammed mine at 125k.........spun a rod bearing a week later.......i was pissed at the time but im happy now with my 383
