View Poll Results: How many miles is too many when thinking about a cam swap?
>50k
5.81%
>75k
14.19%
>100k
27.10%
>125k
52.90%
Voters: 155. You may not vote on this poll
Highest mileage for cam swap *POLL*
Old May 20, 2007 | 09:56 PM
  #41
dave70's Avatar
I'm in the middle of a h/c/i swap right now 114k and like stated above i can still see the crosshatch on the cyl. walls.Plus i'm still on the stock clutch and rear end.But i changed oil pump,and t.chain while i was in there.
Old May 21, 2007 | 08:37 AM
  #42
B4CU's Avatar
This just goes to show you how strong the LS1 really is. My brother's Camaro which was formerly a police car had 150,000+ miles on it and was still going to the strip on the weekends with no problems. That car had been beaten its entire life and just kept going. Your car should be just fine if you decide to do a cam swap. I would say your motor is just nice and broken in at this point. Hope it all works out for you.
Old May 21, 2007 | 03:27 PM
  #43
BlackSVT03's Avatar
I put mine in at 75 and havent had any problems except for a lifter that likes to stick every once in a while.
Old May 22, 2007 | 09:51 AM
  #44
Quik's Avatar
did a swap on a 200+k motor. ran well
Old Oct 4, 2007 | 07:04 PM
  #45
mikenews's Avatar
I love commonsense polls!
Old Oct 4, 2007 | 07:21 PM
  #46
98mysticZ's Avatar
yea so i got 10k out of my cam.... time for a 370 or 408 damn factory spun bearings
Old Oct 4, 2007 | 07:46 PM
  #47
5_02ls1's Avatar
156,000 here...no way i wouldve just put the cam in without some freshening up though......done arp rod bolts new rod bearings ls6 pump and timing set with new gaskets......cam crank bearings and rings are 156k and thec heads have never been off....cylinder pressure was still awesome changed the valvesprings using air method......im sprayin a 150 shot and spinnin to 6500+......
if i could find my damned oil leak though....lol
these engines are amasing
Old Oct 4, 2007 | 07:48 PM
  #48
5_02ls1's Avatar
oh the rod bearings didnt need replacing i done it for peace of mind
oh the poll needxss to go to 200k
Old Oct 5, 2007 | 07:58 AM
  #49
z28ss4me's Avatar
Well, I voted before I read it, so I mashed the >100k button but I would have mashed the >125k button, because I did my swap at 124k. Seems to me if you doing, spring, retainers, oil pump, and timing chain while your there, your actually extending the life of your motor.
Old Oct 5, 2007 | 09:10 AM
  #50
Prerun4fun13's Avatar
Did my cam at 107k and im at 110k and running great
Old Oct 5, 2007 | 10:35 AM
  #51
regorih383's Avatar
Just did a h/C swap on my LS1 at 129k
Old Oct 7, 2007 | 09:21 PM
  #52
OffspringZ28's Avatar
no such thing. cam install reliability is almost based purely on the owner of the car/installer. (ie - how well motor was maintained, cleanliness of install, etc)
Old Oct 7, 2007 | 11:10 PM
  #53
Websy21's Avatar
Depends on the maintenance on the engine and current conditon. I say go for it as long as its in good order even if its on the higher side of milleage.
Old Oct 8, 2007 | 01:34 AM
  #54
LS1Silverado05's Avatar
Bottom line....its a crap shoot no matter what your miles. That pertains to every system in our cars as well. I just killed a 74,000 mile A4...and my brother rails on his 120,000 mile one to this day! You just dont know. So do it...replace what makes sense...and just always be prepared to tear down when it comes time.
Old Oct 8, 2007 | 07:24 PM
  #55
NemeSS's Avatar
50k miles seems kinda high for me, i would rather overhaul engine with heads, cam.
Old Oct 9, 2007 | 09:17 AM
  #56
slt200mph's Avatar
50,000 is nothing on a LS series engine..142,000 on the one I am driving now and it sees the red line dailey and only uses a half quart of oil every 5,000 mles..if these motors are maintained correctly they will last a very long time. I run mine hard but it is maintained well and it still runs very stong..
Old Oct 9, 2007 | 09:50 AM
  #57
PREDATOR-Z's Avatar
Miles are not the only determining factor, but the health of your motor.
My advice before camming:
1- Leakdown test
2- Compression test
Only based on the results then make a decision.
This baby is closed
