? on dual spring install
Old Nov 21, 2002 | 10:25 PM
cy's Avatar
cy
Default ? on dual spring install
Alright, i ordered TR's cam packge #3. Do i use a normal spring compressor to install these springs? Also, it says i need the valve stem seals...ummm...how do i put them on and what exactly are they? Not exactly a veteran with cars, so help is needed. Thanks.
Old Nov 22, 2002 | 12:20 AM
I follow no 1's Avatar
Default Re: ? on dual spring install
You will have to have head work done for the double springs I think.The valve seals slide over the stem of the valve to keep oil from running down between the valve and the head.They are not hard to install.
Old Nov 22, 2002 | 12:37 AM
cy's Avatar
cy
I thought with the Rev 1116's you don't have to have your heads machined to accept them?
With the valve stem seals, i assume its just a matter of sliding it over the valve stem before i put the springs and all back on, am i right?
Old Nov 22, 2002 | 11:50 AM
xaon's Avatar
The REV-1116 springs will not need machining. If you are an f-body, I would suggest buying the valve spring compressor from www.moreperformanceinc.com It will be the easiest option if you are an f-body. If you're a y-body, you can get away with the lever-style compressor from autozone and the likings. Otherwise you WILL cuss yourself. It took the use of 3 people, lots of cussing and frustration, and a lot of time to get the back 3 valve springs done on each side with a crank-down style compressor.
As for the valve seals. They are just a small seal that slides over your valve. You will have to pull your stock ones off to get the spring seats off. If you have a 98-00 car, you can gently remove them with some pliars and then re-use them. If you have a 02 model car, you will have to buy new the old 98-00 style. If you have an 01 model... it's a toss up, somewhere midpoint they switched style. My car came with the new style and I had to replace them out. To install them, you just slide them over the valve stem, and push down. I use a 1/2" deep socket to rest on the top of the seal and push down on it until it wouldn't go down any further. (It pushed down another 1/2 inch or so).
So to reinstall everything, you'll put the new spring seat down, then the valve seal on, push it down, then install the springs and retainer.
I have some pictures at: http://www.cepheid.org/~kris/photos/...nstall/dialup/
<small>[ November 22, 2002, 11:51 AM: Message edited by: xaon ]</small>
