My SS breathes again!! but not with out some bugs!
Well i got the cam installed and hooker long tubes and and pushrods and springs all swapped out and put the car back together and worrked all the air out of the cooling system i did have the heads off to change lifters, but i gotthe car upand running and jsut sounds menacing
couple probs like usual too the car out for a ride couldnt keep it idling once off the gas real quick and got a 1 SES light almost imediatly
which was a PO300 multiple ramdom missfire and i cleared that out with my scan master and thena good while later came back wit ha diff code a po327 Knock sensor 1 low input whats up with that? i did have the sensor out though casue i removed the valley cover but it runs good other wisei cracked oppen the throttle stop set screw a bit and solved my idle issue im still waiting on the maf translator to get here but i got a .563 lift cam and 224 at .050 and 112 lobe seperation any one got any ideas on the deal wit ha fix for this code?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
