Can ARP rod bolts be reused?
I want to open my engine coz my rod is damege (not straight), so i want to chang the rod and i want to know if i can reuse the old ARP rod boltswith the new rod ?
and if i can ,What is the best torque specs for that ?
Thanks
Adnan
<small>[ November 27, 2002, 09:42 AM: Message edited by: oOoLy ]</small>
Thanks
Adnan
LS1Tech Co-Founder
Re: Can ARP rod bolts be reused?
Yes, ARP rod bolts can be reused. We don't reuse the stock bolts because they are designed to stretch when torqued to yield point. The ARP stuff is hardened and does not stretch, which is why we just use normal torque ratings.
I'm not sure on the torque figure, you may contact ARP on that one.
-Tony
-Tony
Nineball, I agree with you on the non-reuse of the stock GM rod bolts since they are TTY however the GM Helms manual says you can re-use them. I wouldn't, though <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thank you Tony and NastyC5 ...... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Now i want to know the torque specs for the ARP rod bolts... !
Thanks
Adnan
Thanks
Adnan
