Pushrod length?
Old Apr 7, 2007 | 06:42 AM
davered00ss's Avatar
Moderator
Default Pushrod length?
I have 7.4's now. I think I will need 7.35 with the new heads. AFR205's milled .030 with stock GM gasket (don't trust cometics, they leak) I know I should use a pushrod length checker, but need to order the pushrods.
Old Apr 7, 2007 | 06:50 AM
PREDATOR-Z's Avatar
no the 7.400 will work fine
Old Apr 7, 2007 | 09:28 AM
Moderator
Will there be any adverse effects of using the 7.4's?
Old Apr 7, 2007 | 09:55 AM
PREDATOR-Z's Avatar
AFR205s have at least .010 taller decks Vs stock castings, and your cam has a smaller base circle so 7.400 would be perfect
Old Apr 7, 2007 | 12:29 PM
Moderator
Thanks.
Old Apr 7, 2007 | 12:43 PM
Cahill93Z28's Avatar
is 7.400 the normal length? Thats what Lengenfelter sells with the GT2-3 cam i want but someone told me to do it right you need to measure the base circ on the cam. Usually aftermarket cams are ground -.030" so you would need a 7.430.
Old Apr 7, 2007 | 01:06 PM
WS6nJAX's Avatar
Restricted User
just use the checker. if the 7.4's dont work your gonna have to measure and reorder anyway. better safe than sorry.
Old Apr 7, 2007 | 03:52 PM
Moderator
7.4 is the longer length pushrod for the smaller base circle cam.
You have to measure preload to find the right pushrod length, I just don't know how to do it. We have always used a 7.35 on milled heads and a 7.4 on stock. Not that it's my car I want to make sure I do it right.
I'm Using new GM LS7 lifters also.
