How much more power from stock 00 Z/28 with a decent heads/cam kit?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I've got a nearly stock 2000 Z M6 with a SLP stainless ram-air, whisper lid, and a loudmouth. Thinking about a ported heads/cam package. Unfortunately, I really have no idea how much more power I'd be looking at b/c I've really just started researching heads/cams. Not taking into account specific manufacturers of the kits, what kind of HP range, depending on the kit I go with? Any information would be much appreciated, guys!!!
You are looking at between 400hp-450hp at the wheels. The 450hp is less common, unless you go with more radical porting and cam, but its all up to your needs and tastes.
The quoted numbers have to be with Long Tube Headers. Without LTs you will not crack 400.
Thanks a lot, I really appreciate the help fellas. Sounds like it will be money well spent!!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
