Rough Idle and Hunting for Idle...
Ive been having problems for a little while with the car hunting for idle on a cold start as well as running rough at idle after warming up.
I was talking to a guy at a local shop in town and he was talking about problems with people running cut outs and no cats (which I was for almost 10 months) bending valves due to no back presure from the exhaust.
Has anyone encountered any problems such as this?
<strong>I was talking to a guy at a local shop in town and he was talking about problems with people running cut outs and no cats (which I was for almost 10 months) bending valves due to no back presure from the exhaust.
Has anyone encountered any problems such as this?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Find someone else to talk to because this guy is a total moron. I've ran a car with open headers before and it didn't bend any valves. Many run cut out's if and there's never been a rash bent valves with the cut outs open. Valves get bent from P to V contact due to weak springs, mechanical over rev, and broken timing chains.
I had TR-6's in my bolt car and hated them. Rougher idle and worse gas mileage. How long have the TR-6's been in? Since they are colder plugs then tend to foul easier and quicker. I'd check plugs and wires. I'd also check O2 connections. An exhaust leak near an O2 could cause various problems.
Good Luck
No leaks on the headers... there were some serious leaks after putting the cats in a couple weeks ago because I couldnt adjust the Y-Pipe. Got that done though, and there are absolutely no leaks. Used aluminum tape to make a "gasket" for the clamps.
My car has always hunted for idle when it is cold with a converter in... just got worse when the headers went in. Then it started throwing rich codes and now Im trying to lean it out again with the MAFT. Base is fine... WOT is NASTY rich.
Just wondering... because at the track Wed. night it was pretty chilly, and the best N/A run I could get was a 13.1@105. Normally can do a 12.7 to 12.8. Would running rich according to the O2 sensors cause running .4 to .5 tenths slower??? Although on the gas... I pulled a 12.2@117. That was on a full tank of gas and tons of crap in my car.
Only point that could cause the problem is where I blocked off the vacuum line going from some kind of sensor to the A.I.R. distributor thing... whatever that is... on the drivers side rear of the engine when I yanked the A.I.R. system.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
