Which Cam will give me the best...
Old Apr 8, 2007 | 03:15 PM
Patrick G's Avatar
LS1 Tech Administrator
Although I feel that a cam in the low to mid 230s on a 110-111LSA will give the most area under the curve (3000-6500rpm) for a heads/cam combination, they are somewhat lacking in the 2000-2500 rpm range. To get a cam that's better than stock in the 2000-2500 rpm range, you need to increase dynamic compression over stock and limit overlap compared to a more conventional "area under the curve" cam. Doing this means that what you gain down low will also somewhat limit you up high. Compromises. But there is hope...
Something like a 218/222 .605/.581 114LSA +4 would work very well with ported heads or with stock heads provided the vehicle had excellent exhaust. You only get 41.5 degrees of overlap at .006" which is outstanding, but the high lift and fast ramps of the intake would still allow you to make strong power to 6000 rpm. Not a bad compromise at all.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 8, 2007 | 07:09 PM
eamador11's Avatar
Originally Posted by 99blancoSS
he wants low end power
yeah.... and what part of G5x-3 @112LSA dont you understand???
Old Apr 9, 2007 | 02:57 AM
PREDATOR-Z's Avatar
Originally Posted by LS1C5Vette
WAY too much lift for me but I know thats where the power is, I want to stay at or under .600 lift and the LSA will be a 112, can TSP do a custom grind?? a 228/230 sounds good, of the two cams (228R or v.2) which will give me more power from around 2500-3000 rpm and up?? Id rather have more umph down low but still have it pull nice through the band up to 6300 rpm, (rev limiter will be @ 6400)
Those lobes are actualy easier on the .006 lift area than XE-R. With the new Gold Extreme springs and cadillac lifters, there is no reason to be affraid.
That cam will spec as a 224.x/224.x and low to midrange trq will be in stroker territory. Also you can shift at 6300 having harnessed a nice band.
cam has only 4* overlap so easy to tune.
I've seen a XE lobed one making 400/400 and a XE-R making 412/414, this one might even top that (definately under the curve)
Old Apr 9, 2007 | 05:05 AM
LS1C5Vette's Avatar
Thanks for all the replys guys, I am going to choose between the two - tsp 228R or tqr v.2, can someone give me a dyno graph of these with the stg 2.5 5.3l heads?
Old Apr 9, 2007 | 06:53 AM
PREDATOR-Z's Avatar
Neither is fitting your original criteria. The TSP 224R on a 112 would be better.
Definately not the TV2, I have that cam and the name is missleading.
Old Apr 9, 2007 | 06:58 AM
brad8266's Avatar
Here is my dyno graph on TEA Stage 3 5.3L heads with a 232/236 on a 112 XE lobes which is fairly close to the torquer(232/234). Makes pretty damn good power in the very low RPM's.
Old Apr 9, 2007 | 07:02 AM
PREDATOR-Z's Avatar
nice, what is your SCR and were you aborting the run early or it took a rapid dive after peak. Very exhaust biased if so.
Old Apr 9, 2007 | 07:03 AM
brad8266's Avatar
Around 11.9, the heads are decked down to about 57cc and I run a .040 cometic gasket. We sut it down after peak power. That dyno session was untuned, Im sure with some tuning it wont drop off so much since it ran too rich. they masured like down into the 10's AFR that run.
Old Apr 9, 2007 | 07:05 AM
PREDATOR-Z's Avatar
That makes sense on so much trq early with VEs being exhaust biased. Good warrior.
Old Apr 9, 2007 | 07:08 AM
brad8266's Avatar
Thanks, its a good street car too. Behaves well on the street, once I get it tuned really well it will only get better. IIRC overlap was biased to the exhaust side by 2 degree.
Old Apr 9, 2007 | 06:37 PM
LS1C5Vette's Avatar
I think ima go with the 228R, I have been misreading a lot of these dyno graphs, thats why I wanted to LOW end power, now that I know how to read them (I feel like a dum ***) I want a cam that pulls from about 2800 up to 6300 and I think the 228R 112 LSA will be good for that what do you think??
Old Apr 9, 2007 | 06:46 PM
  #32
LS1C5Vette's Avatar
Or what about a 228/228 .595/.595 from tsp (custom grind)
Old Apr 9, 2007 | 07:39 PM
  #33
kilrb's Avatar
That TSP cam isn't even in the same category with Thunder cams when it comes to power under the curve. I love the TSP guys so don't get me wrong there, I'm a loyal customer. BUT until I see a cam beat the TR224 at its own game I'll stick with it for a recommendation for someone who is looking for power under the curve without losing anything down low.
Not to pick a fight or anything, but I don't see how Thunder's 224 is going to be in a different league than the Texas Speed 224 on XE-R lobes (.581 lift). Unless I'm mistaken, when I did my homework, I was told that the XE-R lobes are sligthly more aggressive than Thunder Racing's. I don't see how the same intake/exhaust duration and LSA with less lift is going to blow away the same specs with roughly .020 more lift...
To the original poster, I settled on Texas Speed's 224R with their Stage 2.5 5.3 liter heads in my 99 FRC Vette. Everything is in (long tubes, cats, underdrive, LS6 intake, Vararam), and I have a tune scheduled for the 23rd. I'd be more than happy to share my dyno graph with you after that date. From what I read in my research on this forum, the 224R should give a little better low end grunt, while sacrificing a few horses up top. I was really wanting something with some nice low-end, so I went with it as opposed to something bigger. That, and I didn't want too much lope (the 228R has 4 degrees more overlap, and thus more lope). There are other members on the board with the 224R cam-only, and one or two with heads. Check around... Good luck!
Old Apr 9, 2007 | 07:45 PM
  #34
brad8266's Avatar
The 224 range cams can make huge power everywhere, just look at Patrick G's setup as proof.
Old Apr 10, 2007 | 01:05 AM
  #35
PREDATOR-Z's Avatar
Another cam to consider is TR230/224 reverse. Heck of a cam for that range duration.
Old Apr 10, 2007 | 02:08 AM
  #36
LS1C5Vette's Avatar
dammit, its between the 224r and 228r now, mabye I should have a custom grind that a 226/226 .593/.593, there thats in the middle of the 2!!
Old Apr 10, 2007 | 02:18 AM
  #37
jegten's Avatar
hey, LS1C5Vette,
what cc are you getting those heads in, and valve size?
i am looking at getting those heads.
there are some people running the 228r already. do a search on it, and also go to ls1gto.com, i know a couple of people have posted their experiences with it.
also, FTI as a cam with slightly higher lift, 224*-228*-111*-.600"-.600" Rebel TQ.
or 220*-224*-111*-.597"-.592" StreetSweeper-TQ
anyhow, hope that helps. and let me know.
thanks.
Old Apr 10, 2007 | 02:23 AM
  #38
LS1C5Vette's Avatar
Originally Posted by jegten
hey, LS1C5Vette,
thanks.
I dont remember what cc they are but I do know that they have smaller combustion chambers for a 10.75:1 compression ratio and they have the stainless steel 2.04" intake/1.575" exhaust valves
Old Apr 10, 2007 | 02:38 AM
  #39
PREDATOR-Z's Avatar
5.3s are between 63>64cc ported, I have a set of these on my 370cid, mine were 64cc
Old Apr 10, 2007 | 10:30 PM
  #40
LS1C5Vette's Avatar
Ok, now I have changed my mind AGAIN, I like what I see about the 228R but I dont think ill be happy with that, I am leaning more toward the Tqr V.2 OR mabye even the 233/239 cam. Whick one of these will give me better 1/4 mile times and faster 30-150mph times??? Is the 233/239 even a streeetable cam? I know the V.2 is. P.S. this is NOT a DD car, but I dont want it to turn out like a dragster...
