Which Cam will give me the best...
231/240, .643/.608 112+4 LSA
Will drive like a 228 and make power like a 236
I am going to say that Predator knows his stuff so you may want to really consider his suggestions rather then trying to stick with an off the shelf cam by TSP. Just my 2 cents there.
452 RWHP with a 224/228? and that gearing?!
a set of LS6 heads and a 233/239 cam wouldnt even net 440 RWHP based on the other thread I just made..
But a 224/228 can make those numbers, look up Tony Mamo's AFR 205 thread and he made close to 480rwhp. It is all in the details of the combo with countless hours of dialing, prepping and dynoing the setup.
Of course this cam would only fit in stock valved/gasket/unmilled setups, like a cam only.
Would it be adviseable to go with other lifters? Yes for reliability purpose.
232/240 .595/.608 112+4 XE-R lobes.
Better than TV2 due to the exhaust split.
BTW that is a G5X2
BTW that is a G5X2
so TSP can do a custom grind on this cam correct?
BTW that is a G5X2
That is the graph from a 01 z06 with intake, exhaust, pulley, cam only with g5x2 on 114+4. This gives you an idea of how the cam will pull, granted that is an ls6 but with the 5.3 heads I would guess you may have more torque down low also with the cam ground on 112+4 your torque should be a little better. I do not know much about the 5.3 heads, but here is a link to the thread about his car if you want to read more.
http://www.z06vette.com/forums/showt...highlight=g5x2
There are several posts about driving with that cam.
Read post #12 he explains how it drives, but again on the 112+4 and 5.3 heads your car would make a bit more down low and drive better I would have to assume.
Someone please correct me if I am wrong on any of this.
On a side not u are an okie..... NICE!
