Are LS6 springs more durable than Comp 26918's?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fenris Ulf:
<strong>The LS6 springs are a better choice since they are factory equipped (obviously) and better for longevity with your low lift cam.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto what he said, for low lift cams there isn't a better spring out there IMO. There are tons are cars running around my area running big duration cams with low lift and 02 LS6 springs. I have never heard of one problem with them. If you're running .540 or under, 02 LS6's are the way to go.
Josh
Josh
After doing many searches, what I seem to have found is that for a cam with moderate lift (around 0.530") the LS6 springs are sufficient. I also understand that with lifts above 0.550" aftermarket springs are needed.
My question: If I am using a moderate lift cam, am I better off with the Z06 springs. My MAIN concern is durability, not the fact that the LS6 springs are cheaper. I just don't want to have a failure!
Note: Car is used for road racing lapping days and sees two hours of constant 3000-6000 rpm per event (20-30 min sessions).
<small>[ November 29, 2002, 12:03 PM: Message edited by: Gary U ]</small>
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Try the SLP springs, there just like the LS6 sprins but have more preasure on em. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
