ported oil pump = low oil pressure?
will a ported oil pump cause a lower oil pressure? i am looking into buying a car that has a fair share of aftermarket parts on it and i noticed it reads around 20 psi at idle. will the ported pump cause this? it does raise with rpms so i am not too concerned but i was more or less curious.
if the oil pickup o ring gets ripped or pinched, it will cause low oil pressure. Who did the work? Does the guy know what he doing? It's a common problem when people are installing an oil pump that the ring get pinched or ripped if they're not paying attention. The oil blows pass the o ring and can't build pressure.
Originally Posted by cals400ex
so you dont' think a ported pump will cause a decrease in pressure?? you think it is more than likely a bad pump or bad o-ring?
