What's up with my ride???
Old Nov 28, 2002 | 09:07 PM
99BackNBlackZ28's Avatar
Default What's up with my ride???
Alright guys, ever since I had my hooker longtubes installed...I've had issues w/the way my car runs.
I have a slightly rough idle @ 650rpms, but it only happens sometimes. During normal times the car idles about 900 rpms or so.
Also if I let the car sit for a minute at idle, like at a stoplight, the car hesitates when I try go, then backfires! Again, only sometimes.
Could this be a vacuum leak...like the AIR tubes or whatever arent sealed well enough, or is it something totally different.
Today I also noticed a slight "whining" sound when going up to redline in first gear, but I couldn't get the car to do it again.
Thanks for any advise or ideas.
Old Nov 28, 2002 | 09:42 PM
99 Black Bird T/A's Avatar
Default Re: What's up with my ride???
My Hooker Headers
O2 bung misaligned so badly O2 sensor wouldn't fit
1/4 inch gap on primary because not welded - compressed air blew thru it - leak!
Several primaries had to have slag removed
Flange required filing to smooth out.
Driverside O2 rubs against car. Needs relocating.
Any tuning?
What's your A/F?
Any Atap data?
Many cars run too rich with long tubes because the O2's are moved and see cooler temps.
Old Nov 28, 2002 | 10:21 PM
Unfortunately I have no data as of yet. I'm having the car autotapped on Saturday, so hopefully that will give me a little insight. Also, I was told to change out my fuel filter. I've had the car for about 12K miles and I dont know if it was changed before I bought the car or not, so I'll get that taken care of.
Old Nov 28, 2002 | 10:22 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99 Black Bird T/A:
<strong>My Hooker Headers
Any tuning?
What's your A/F?
Any Atap data?
Many cars run too rich with long tubes because the O2's are moved and see cooler temps.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How did you go about getting all those problems with your Hooker headers taken care of?!
Old Nov 29, 2002 | 09:09 AM
blackend02's Avatar
Ihad hooker lt on my 2002 SS that i got from jet hot that were great , as far as tuning goes id reset the pcm than atap on a dyno to see what is really going on . <img border="0" alt="[Z06 Corvette]" title="" src="graemlins/z06.gif" />
Old Dec 2, 2002 | 12:42 AM
Haus095's Avatar
Sounds just the same as my car ran. I had a bad O2 sensor on the front drivers side. Replaced it, and the car idles fine and dosn't hesitate off a red light in the morning anymore.
Old Dec 2, 2002 | 01:04 AM
sited12's Avatar
It sounds like you have a vacuum leak. Did you use new gaskets for the EGR and AIR tube. Remember if you bent the EGR tube just a little bit it would of caused a leak. Found that out when i did the free EGR mod.
