TR 227/224 cam in a 2002 Z06- results
#61
Re: TR 227/224 cam in a 2002 Z06- results
I'd agree with Paul on this one. This cam + GTP stage 2 heads is probably good for 440-450rwhp.
If you don't want to spend the money on GTP's, I'd just get plain LS6 heads like I have and use those as a lower cost alternative.
<small>[ December 05, 2002, 08:56 PM: Message edited by: Z06Cam ]</small>
#62
6600 rpm clutch dump of death Administrator
The CNC head has the combustion chamber reworked extensively. The LS6 stock chamber starts at around 67 CC to begin with. Once the chamber work is done they are over 70CC. So they mill .055 to get them back to 60cc...
#63
!Dial-up Director
SAC, the only silver T/A you will be <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> is mine. From a 170mph roll of course. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Justin
Justin
#64
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ramair346:
<strong> These heads have been milled 0.055" to bring the combustion chambers back down to approximately 60cc.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What kind of heads do they start out to be?? .055" is a lot of milling. If they are LS6 heads to start with they would only need to be milled about .030 to get to 60cc. If they are LS1 5.7 heads then that would make since. If that's the case though I would just go with 5.3 heads with just a clean-up milling and you would be right there and no valve train geometry issues.
Paul
Paul
#65
They're supposed to be LS6 heads. The GM part # description says they're LS-6 also.
I'm starting to think I should maybe look into a different set of heads though. The reason I was hopped up on getting them is because I figured if Z06cam pulled 423 out of stock heads, these should flow a bit better and not to mention they're $2200 with no core.
#67
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jsears8:
<strong>SAC, the only silver T/A you will be <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> is mine. From a 170mph roll of course. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Justin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You gonna get someone to drive it that knows how to keep from frying the clutch??? <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
Cameron, I was hoping to see you saturday but you werent there. The track is open today also. You oughtta go if you can.
<small>[ December 08, 2002, 09:37 AM: Message edited by: 2000SILVERTA ]</small>
#68
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000SILVERTA:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jsears8:
Cameron, I was hoping to see you saturday but you werent there. The track is open today also. You oughtta go if you can.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry SAC. Had to fly out to CA on Friday on short notice for a funeral. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
BTW, nice ET's this weekend! If I run that well I'll have a heart attack! lol
