GM stock rings pistons.....gap
Old Dec 3, 2002 | 02:28 PM
oOoLy's Avatar
Default GM stock rings pistons.....gap
Hi,
Does any one know what is the best gap I should have on my stock bore rings for n/a engine ?
Thanks
Adnan
<small>[ December 05, 2002, 05:34 AM: Message edited by: oOoLy ]</small>
Old Dec 4, 2002 | 06:05 AM
oOoLy's Avatar
Default Re: GM stock rings pistons.....gap
ttt
Old Dec 4, 2002 | 04:07 PM
steve's Avatar
give me the specs of the motor, and what is planned use is. ill let you know what i ocme up with as far as preffered gap.
steve frank
Old Dec 5, 2002 | 05:24 AM
oOoLy's Avatar
I will get stock GM ring for stock bore , and i want N/A engine ?
my mods in the sig.
Thanks
Adnan
Old Dec 5, 2002 | 06:41 AM
Redline-Motorsports's Avatar
The minimum gap is figured by mutliplying the bore size x .004". Example 4.00" bore x .004" = .016" min. end gap on top ring. I believe the 2nd ring is factored with a .003" multiplier.
This is the "rule of thumb", however I the LS1 is a usually setup a litle different that that. I just set my top ring to .020" and the bottom larger to .026". This was for a 4.080" bore. The larger bottom gap helps control ring flutter at high rpms, especially with these thinner designed rings.
Old Dec 5, 2002 | 06:54 AM
Bob2of3's Avatar
Wheels up Director
I'm using the stock pistons with Speed Pro rings and my gaps are top- .018, second ring- .022
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 5, 2002 | 07:22 AM
oOoLy's Avatar
Thank you all for your reply ...... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I want the best gap for N/A engine ..
If i set the top- .018, and the second ring- .022 it will give me good power ?
I want the best compression... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks
Adnan
<small>[ December 07, 2002, 01:16 PM: Message edited by: oOoLy ]</small>
Old Dec 6, 2002 | 06:13 PM
joghotrod's Avatar
I recently took a 01 LS1 engine apart that had 12000 miles on it. Just for grins, I checked the end gap on the top ring in one of the cylinders and it was .010. Seems tight but who knows what Chevy sets them at from the factory. Jimmy
Old Dec 7, 2002 | 01:23 PM
oOoLy's Avatar
I need more info ...plz
Old Dec 7, 2002 | 04:20 PM
Boosted LS1's Avatar
I would suggest using the sae recommendations as outlined by 9D9LS. You may find that a set of stock aftermarket rings 'off the shelf' will have the gaps set to large and obviously you can't reduce them any tighter. If you want the best option then maybe go and buy 'file fits'. Then you can be sure of getting the gaps set nearer the minimum recommended settings.
Old Dec 7, 2002 | 06:36 PM
LS1derfull's Avatar
GM reccomends .009" to .0019" for top ring and .017" to .030" for second when replacing stock rings on a used motor. My take on these specs is since pistons are hypereutectic then upper ring gap should be large, but since block and heads are aluminum this must bring specs back down to compensate for heat transfer. On second ring GM must agree with theory of large gap keeping pressure from being trapped between upper and lower rings and causing flutter. Thats only logical reason spec of .029" would be suggested.
I would stick with tight tolerance on upper and close to max on second, but before i ran .009" on upper i would inspect old upper ring for butting on ends(shiny finish) and check its gap about .500" down in bore. Also this inspection assumes you had mods done to original motor. Meaning extra heat from cam swap, raised rev limiter, head work and or compression increase.Stock motor will tolerate tighter gaps than motor with all these mods.
Old Dec 9, 2002 | 02:47 PM
oOoLy's Avatar
Thank you all ....
You gave me many numbers for gap <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> but i need the one wich gives me the best N/A power i can have ?
Thanks
Adnan
Old Dec 10, 2002 | 05:23 AM
oOoLy's Avatar
If i get .014" for the top ring and .016" for the second ring, it will be agood engine ?
Thanks
Old Dec 10, 2002 | 05:43 AM
LS1derfull's Avatar
If you read what i replied it tells you what to do to know min. safe gaps. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
By Brett Foote | 2026-06-04 05:00:17
