benefit of milling heads??
you need to cut down the alignment pins on the plastic manifold if u use milled, heads, however....
In addition, a TR-220 cam will be installed.
Below is what I understand to be true:
Milling 5.7 LS1 heads .035” will decrease the stock 67.3cc chamber volume to approx 63cc
This will yield a 10.7 to 1 compression ratio when the stock GM .052" thick graphite head gaskets are used.
<strong>OK, what are the pros and cons of a higher cr??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">pro - rwhp <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
con - knock retard ( need higher octane fuel )
