Inside of the Intake is shiney....could it be?
Could it be that my PCV valve is done with...
When I looking into my intake 2 months ago it seemed to be dry in there...
Is this oil, its a black black...
I also want to say that if you go back and reread
Jan. 2002 GM hi tech article about John juriga from GM engineering adressing oil consumtion cause, he spells it out pretty clearly. The oil scraper rings expander tension is just adequate, and second compression ring only has enough tension to clear oil off cylinder when motor is kept out of hi rpm/part throttle conditions like cruising along at 3000 to 3500 rpm with only part throttle. Engine rpms have to be kept as low as possible when driving easy or hi manifold vacuum unseats second compression ring and allows oil to be consumed. This does not mean it doesnt seal properly at wot under hi rpm and load, because it does seal.If you see oil smoke out tailpipes full throttle it is from oil collection in intake being sucked up into cylinders. When 3000+ rpms are used to get around and ring unseats this also causes blow by into oil pan which pushes and carries oil into pcv system causing consumption also. A3 guys will always have a problem with this, but us M6 and A4 cars can fix most of this by keeping rpms around 2000 until race time.
If GM fixed this situation completely by raising ring tension dramatically or using thicker more conventional rings the LS1 will lose power. I would rather drive smart and keep race style rings in this motor. I hope this helps some understand what the deal is with all this. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
