TRak Camshaft with LS6 heads
I wouldn't touch those with a carbide cutter unless you're a very experienced porter. They're a good head for money. In your case you're going to have a higher-rpm motor and they should work really well.
What should you expect? Of course HOSS put 430+ to the wheels with a TRak cam, Fast 90/90, and stock 853 heads. So, with a good intake on your car it could be really impressive!
Ben T.
Also, look into the work that TEA can do to your ls6 castings.
Stage III 1020 Superflow Bench 4.125 Bore
Lift 2.08" Intake 1.60" Exhaust
.100 78 cfm 66 cfm
.200 147 cfm 124 cfm
.300 209 cfm 164 cfm
.400 255 cfm 206 cfm
.500 296 cfm 229 cfm
.550 312 cfm 232 cfm
.600 322 cfm 237 cfm
Best of luck!PS..what did you make cam only?
. I plan on getting the fast 90/90 within a couple of months, so hopefully it will clear its breathing quite a bit
