At 471rwhp now, how to hit 500rwhp?.......
Old 12-14-2002, 01:56 PM
Crazyquik's Avatar
Default Re: At 471rwhp now, how to hit 500rwhp?.......
New alum shortblock or keep the iron?
1) keep the iron bullit
2) get the nitrous kit out of the closest
3) paint the car so no one in Chicago recognizes it
J.
Old 12-14-2002, 01:58 PM
Formerly 4mulaJoe
LS1x2's Avatar
Id 't try some different heads since it looks like you are going to spend alot of money anyway.
Old 12-14-2002, 02:25 PM
The Juggernaut's Avatar
If you're concerned with dyno numbers-EWP and pull the belt.
if that doesn't do it-open headers.
and dyno on radials @50 PSI.
Maybe custom intake with a carb on it.? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 12-14-2002, 05:30 PM
Angry'Z's Avatar
PSJ,
I like the idea of a better flowing intake like the sheet metal intake from More Performance - lots of money but I bet you might be able to cram quite a bit more air into the engine. I don't know though - 471rwhp on 28 drag radials - sounds like you might be close already. Dyno's are for engineers, timeslips are for racers. Can you sit on it for four months and get about two miles under your belt a quarter at a time <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Michael
ps no flame intended for any engineers out
there
Old 12-14-2002, 06:04 PM
steve's Avatar
i would say try running a 4.150 bore block with a short stroke.
how about this.
4.150 bor x 3.52 stroke....
that comes out to 380 inches.
drop alot of dope in it and spin her to the moon.......
steve frank....
"the man who liketh short stroke"
<small>[ December 14, 2002, 06:49 PM: Message edited by: steve ]</small>
Old 12-15-2002, 12:09 AM
Terry Burger's Avatar
I say go for the alum block AND 1 7/8" headers. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 12-15-2002, 12:46 AM
Moderator
xp3nd4bl3's Avatar
<-- votes for more head flow! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 12-15-2002, 08:41 PM
1CAMWNDR's Avatar
I say try a solid cam. As far as the exhaust goes, 1 7/8 headers with an X-pipe, Race Magnums and turndowns. You don't need the extra weight of a Y-pipe & cat back at the strip.
Those two will probably get you another 30 hp.
Old 12-15-2002, 08:47 PM
sited12's Avatar
I like the post about spraying and painting it so no one recognizes it. To bad you showed everyone on the chitown board the new hood plus people know what you look like. Im sure i could pick that car out in a parking lot of racecars.
Old 12-15-2002, 10:25 PM
Chicago Crew UnderBoss's Avatar
John:
RADICAL HIGH LIFT SOLID ROLLER>SOLID ROLLER>SOLID ROLLER, spinnint to 7200+ and 1 7/8 Headers and you should be at 500rwhp no problem.
MTI 427 C5 Roadster
Old 12-15-2002, 10:34 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,135 Likes on 739 Posts
Angry, no, that was on the equivalent of 28 inch tall ET streets. I can supposedly pick up just from dynoing on a regular radial, maybe 5-10rwhp?
I think I will do some 1&7/8 headers but I hear they are tight around the steering shaft.
Old 12-16-2002, 12:02 AM
  #32
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As long as you had 30+psi in the tires I don't think it matters much. Test it out and let us know. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 12-16-2002, 12:27 AM
  #33
99RamAirTA's Avatar
Call me crazy but I think he should go with a big bore and keep the big stroke to. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> I figure if you own a LS1 chat site you should have the big dog motor. 4.15 bore and a 4.125 stroke comes out to a 446 on my calculator <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Then after that I would pick up the 1 7/8 headers and the new intake. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> Then when the combo is all sorted out and running good.... spray the ever living hell out of it <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old 12-16-2002, 07:42 AM
  #34
Closed ex-Sponsor Account
Ed Potter @ LPE's Avatar
I'm with 99 ramair T/A, a guy in your position should have a stout engine, and 440+ inches in an LS1 is stout no matter how you look at it. The 1 7/8" headers are the way to go, and I would also recommend stepping up the intake valve size, and portwork in the bowl area, to take advantage of the HUGE cubic inches. I think you can reach your goals without even using the spray.
Ed
Old 12-16-2002, 07:48 AM
  #35
LS1Tech Co-Founder
Nine Ball's Avatar
T56 6-speed conversion
Replace 9" with 12-bolt
Dyno on radials instead of slicks
I also think a site owner should have a BIG motor, or at least a quick car <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
hehe
-Tony
Old 12-16-2002, 10:49 AM
  #36
1CAMWNDR's Avatar
John, if you do decide to go with a bigger motor; you need the baddest *** Pontaic motor number there is: 4.19" bore and a 4.125" crank equals 455.02" Super Duty! <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old 12-16-2002, 11:47 AM
  #37
Nasty N8's Avatar
I agree more head work and bigger valves. Do headers with ex., quiet that thing down. If you want the big motor let me build it I will get you 500hp 4.155 bore and 4.125 stroke big solid cam and you are looking at wheel standing TQ <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
And I am with Tony stop playing with that automatic!
Nate
<small>[ December 16, 2002, 11:49 AM: Message edited by: Nasty N8 ]</small>
Old 12-16-2002, 01:21 PM
  #38
I'm not sure about max bore.
But I think the maxium cubic inches(bore and stroke) is 471ci.
(but don't quote me)
Someday I will know for sure. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 12-16-2002, 02:26 PM
  #39
LS1Tech Co-Founder
I think the C5R can go like 4.150 bore max, and I personally would never go over 4.000 stroke since I'd like to buzz some rpms some day.
Old 12-16-2002, 09:27 PM
  #40
SSU Moderator
RyanJ's Avatar
c5r's can do 4.160.
john has a 4.075" crank, not a 4.125.
provided that dyno was locked and you didnt have any electrical issues at the time, i say throw some radials on it, get that intake, and try a cam recommended by Wade. I still think the heads would like a standard split cam. if your are certain the port flow is %-wise comparable to stock, you could go reverse. OR just ditch that nasty 9" with 4.10's and make it a street car. that would free up a few ponies.
