393 All-bore Solid Roller cam
Old Dec 13, 2002 | 08:16 PM
M6's Avatar
M6
Default 393 All-bore Solid Roller cam
Ok guys I need some help picking my solid roller cam specs.
The cam is going in a stock stroke, 4.155 bore, 393 ci MTI built motor.
I plan on shifting @ 7200 and need it to be decently driveable and idle reasonably, but I definitely want an aggressive cam. I'm thinking ~240/245 ~.630/.630 112 lobe sep
Thoughts??
'02 Red SS, Strange 12 bolt w/ 4.10, Cartek clutch, 28" ET Drags
Old Dec 13, 2002 | 08:41 PM
Alonzo Version 1.0's Avatar
Default Re: 393 All-bore Solid Roller cam
If you are going with a split pattern then go reverse split.More intake duration than exhaust.Also solid rollers have more driveability than hydraulic cams so I think you will be fine in that area.My personal choice would be a single pattern 245/245 650/650.Of course people do call me ignorant.Good luck either way.
Old Dec 14, 2002 | 01:09 AM
Fenris Ulf's Avatar
a 240/245 definately will want to be shifted much lower than 7200. You will need to go bigger.
Old Dec 14, 2002 | 03:09 AM
Jason99T/A's Avatar
I can shift faster than you.
The great thing with the solid roller lobes is you can get very aggressive without affecting driveability. If you plan on a 7200 shiftpoint, I would look into a much bigger cam. I would look at something in 25x range. Are you using LS6 heads?
Old Dec 14, 2002 | 09:52 AM
M6's Avatar
M6
Thanks for the input guys. I will be using MTI Stage III LS6 heads.
Has anyone used a reverse spilt cam on a larger bore motor? It seems like most people are using a R1 or a similar traditional split cam.
Is there anyone using a solid roller on a ~393 ci motor? I want to have an agressive cam but I don't want to overcam this motor. From what I have read you can go about 8* bigger on a solid roller than a hydraulic roller and have the same driveability, which makes 25x seem a little large. Comments??
Old Dec 14, 2002 | 01:15 PM
CHRISPY's Avatar
Why not offset grind the crank to 3.72?
Then you will have around 404 cubic inches <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
cheers,
Chris
Old Dec 15, 2002 | 04:44 PM
Chicago Crew UnderBoss's Avatar
You will have one AWESOME MOTOR and 10.00 second 1/4 mile car with that engine coupled with a solid roller cam. I would just stick with what JAYSON at MTI recommends to you and you certainly will be able to run quite a radical lift cam in that motor since your going solid roller.
I would just tell Jayson what you want the car built for and based upon your goals he will hook you up no doubt.
MTI rocks and so will your car!
MTI 427 C5 Roadster <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" alt="[Corvette]" title="" src="graemlins/corvette.gif" />
Old Dec 15, 2002 | 04:47 PM
Chri ARE 60
OUt of curosity, how many cubes would a 4.060 overbore make on a LQ4 using the offset on a stock LS1 crank.
THanks,
MTI 427 C5 Roadster
Old Dec 16, 2002 | 12:15 AM
M6's Avatar
M6
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>Why not offset grind the crank to 3.72?
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I thought about that. I'm not to familiar with the process though. How much machine work is involved? (How much $$)
Any more suggestions on the cam?
Thanks for the help guys!!
Old Dec 16, 2002 | 07:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MTI 427 C5 Roadster:
<strong>OUt of curosity, how many cubes would a 4.060 overbore make on a LQ4 using the offset on a stock LS1 crank.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Using a 3.75" offset stroke, it would yield 388 CID <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
