HELP!!!! Spring Swap Nightmare!!!
Old Apr 19, 2007 | 06:01 AM
LS1MCSS's Avatar
Originally Posted by Demon_Speeding
Well, after reassembling the car, making the sign of the cross and saying a few prayers I fired the car up. It sounds absolutely WICKED with the MS4 in it. After getting the car out of the garage and cleaning up a bit I found the long lost lock. It had made it under the cardboard box I had laid out to catch drips here and there. It looks like I must have slid across the top of the lock while I was under there because there was a spot on the cardboard where it appears the lock stuck to it when I lifted it up to look at it. Needless to say, after the car was out and I picked the box up the damn lock un-stucked itself (In my 4 year old daughter's words) and fell on the floor.
Thanks to all for your help.
Glad to see you found it. I was taking my springs off, with the heads on the work bench, and two of mine took flight across the garage. I have yet to find the damn things.
Old Apr 19, 2007 | 06:46 AM
dc160lti's Avatar
Well imo when you get stressed out now just listen to that video because that was 10 times better than your avatar.
Old Apr 19, 2007 | 08:44 AM
radkon's Avatar
You dodged a bullet. The first spring swap we did on a buddy's car one of the locks disappeared. We debated for an hour on what to do. We ended up pulling the head and there it was resting right next to the lifter retainer.
Word of advice to ALL spring swappers, plug the head bolt holes and anything else before you start.
Old Apr 19, 2007 | 04:58 PM
Shinobi'sZ's Avatar
I know the f'd feeling you are experiencing...but I dodged the bullet.
I was replacing my springs and something slipped (I always use a magnet as I get close to colapsing the spring to catch the retainers) but I slipped leaning over the car and the under the spring load the retainers went flying.....luckily (and I couldn't even believe it) they both fell under the car and I retrieved them...but I had the same feeling that you have....good luck man.
