HELP!!!! Spring Swap Nightmare!!!
I'm doing a cam/spring swap, and I was swapping the springs on the #4 cylinder, using the Crane tool. Since my hand and the ratchet were in the way, I was watching the exhaust valve (since it was closest/easiest to see). Once the locks were free on that one I stopped and removed the ratchet. That's approximately the same time I filled my underwear... Where the F**K are the locks!?!?!? The intake valve (one I couldn't see) was missing it's locks. I had already dropped one while doing the #8 cylinder but managed to recover it. After much looking around with a flashlight and dragging a magnet all over the place I found one of the 2 locks right next to the head bolt circled in the pic below. FYI I just snagged the pic off LS1HowTo for reference.
Trying to find it I have;
- Fished around the top of the head with a magnet.
- Fished around in the pushrod holes with a magnet.
- Fished around the head bolts with a magnet.
- Had the wife shine a light under the car and watch for any flying objects as I blew compressed air across the K-member and around the passenger side of the block to include the header and all the surrounding areas.
Frankly right now I could literally
I'm so pissed and upset. I have a bad feeling I know what kind of response I'm going to get... Here's what I'm afraid is coming... Pull the passenger side head and start looking (praying to God I find it there). If not support the motor, drop the K-member and oil pan and hope it's in there.Here's another question. Suppose I tear the damn motor completely apart and don't find it?
Somebody PUHLEEEEZE help!
As vettnuts says, look carefully in p-rod holes, it can do some damage there.
Last night when I posted I was tired and frustrated as hell. This cam/spring swap has been one PITA after another... Maybe that's why it's taken me almost two years to get the motivation together to do it.
I'll keep the thread updated with what I find.Thanks again!
Jason
But suggest for the rest of them (if there are any more to do) or next time, use some rags around the area and some magnet(s) near by as you release the locks and that way you will either collect them on the magnet or fall in to the rags and not get lost should they slip away from you.
It is quite soothing when I'm frustrated with the car. When I made the original post in this thread I kept getting distracted and looking at it...
Thanks to all for your help.
Without further ado... The vid!!!
