Doing H/C this winter, what gaskets and bolts??
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Get some ARP head studs and cometic gaskets...and never have to replace this stuff again... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BlackWS6LS1:
<strong>Do I need beside the Heads gaskets and bolts, FYI using all GM stuff....
Thanks in advance...
Tom</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
The Bull
Timing cover gasket and water pump gaskets are optional. The stock onese are metal with the silicone seal. A timing cover crank seal is highly recommended since you have the cover off. Other than that there isn't a ton of things to do. Especially if you get some studs and either cometic gaskets or the spring steel GM gaskets.
