346 cu in, big valves, idle problems??????
I was told your car didn't want to idle with the big valves. When you put on the small valve heads the idle improved alot. What gives?
Vinnie...when Brandon and I took your car around the block post head swap...it seemed to idle better at first. Then you said after a few days of driving the hot starts came back. Maybe thats the confusion.
