ls1 402?
Old Apr 14, 2007 | 02:02 PM
1slogto's Avatar
Default ls1 402?
Hey is it possible to bore my sleeves to 4.00" and put a 4" stroker crank in it without re sleeving. Iam looking for a cheaper way to build my 402 that buying a ls2 block. I searched and couldnt find any info on a ls1 402 just ls2s. Any info will help thatnks.
Old Apr 14, 2007 | 02:05 PM
teke184's Avatar
i think you hve to re-sleeve it.
don't think you can go much bigger than 382 without compromising cylinder strenght and integrety
Old Apr 14, 2007 | 02:06 PM
Black02SLPSS's Avatar
i asked a similar question awhile ago and apparently you can only bore it .010 over before having to resleeve
Old Apr 14, 2007 | 02:08 PM
1slogto's Avatar
damn i dont want to have to buy an ls2 or resleeve the ls1. Does anyone know how much a set of 4.00" sleeves would run me?
Old Apr 15, 2007 | 12:46 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default 4" bore
The machine work alone to install the sleeves would cost more than a new LS2 block. The least expensive way to a 4" bore would be an iron block unless you can find a good used LS2 block.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Apr 15, 2007 | 12:57 AM
brad8266's Avatar
Ive seen LS2 blocks go for a few hundred bucks used.
Do not try to bore the LS1 out any more than 3.91, the common bore for the LS1 is 3.905.
Old Apr 15, 2007 | 01:12 AM
bayer-z28's Avatar
I think the C5R block is the only way to go w/ a bigger bore. IIRC, you can't punch the LS1 stock block. Too thin of sleeves.
LS2 can do it w/ a new rotating assembly, I'm pretty sure.
Old Apr 15, 2007 | 10:52 AM
1slogto's Avatar
i might be getting a 6.0 iron block from a friend that is taking it out of his truck and parting out the truck. I didnt want to go with the iron block because i already have such a heavy car, but it looks like its time for some more weight reduction.
Old Apr 16, 2007 | 06:19 PM
If i were rich and famous i would go with a C5R block but i cant cough up 6k for a block on its own lol
Old Apr 16, 2007 | 06:24 PM
Bandit28's Avatar
If you want to go the route of re sleeving. Check out the erl performance 500 inch ls1
