Torquer V.3 owners chime in!!
Old Jan 16, 2008 | 11:08 AM
  #61
LSGunZ28's Avatar
but I ponly have an LS6 manifold and ported my own stock TB
Old Jan 16, 2008 | 09:02 PM
  #62
SweeTbone's Avatar
Originally Posted by LSGunZ28
what kind of rearend are you making those #s through?
I should make he same HP as you.. I have a 12 bolt, but I also have an aluminum FW and no cats...
Stock rear end. 3.42s in the back. Cats might have killed about 5 HP.
Old Jan 16, 2008 | 09:55 PM
  #63
LSGunZ28's Avatar
I see
yeah I think Id make about a hair less power than you... did you change rocker arms? what spark plugs?
thanks
Old Jan 16, 2008 | 11:34 PM
  #64
ABQ99TA's Avatar
I have had this cam for a few months and I love it. I'm cam only and put the #'s in my sig down. I used 7.4 prs the graph looks sweet. There is a ms3/termi car in town and at the track we ran with in .06 in the 1/4
Old Jan 16, 2008 | 11:39 PM
  #65
SweeTbone's Avatar
I see
thanks
Nope. Stock rocker arms and NGK TR55 Plugs. REALLY close to ordering some TSP Duals to see what that does for the HP.
Old Jul 14, 2009 | 10:22 PM
  #66
DarkhorSe_SS's Avatar
current torquer v3 owners post more opinions...
-post some vids
Is this cam a slug at the lower 3k rpms??
Also, I read on page three the car had to be going over 70 in 6th gear??? wtf....
Old Jul 14, 2009 | 10:46 PM
  #67
jcolews6's Avatar
Cam is real slug at 3k!!
Old Jul 14, 2009 | 10:55 PM
  #68
How long have u had the cam? Is it properly tuned also?
Old Jul 15, 2009 | 12:41 PM
  #69
TX RED's Avatar
750 idle
http://www.youtube.com/watch?v=fjO3VRT-2Nw
950 idle
http://www.youtube.com/watch?v=ZyfxxyZF77U
Old Jul 16, 2009 | 06:07 PM
  #70
SweeTbone's Avatar
I wouldn't call it a slug, but 3K is when it starts to ramp up. Off idle it's all right, but it's not a super torque monster off the line. 3K to 6.8K it's money IMO.
Old Jul 16, 2009 | 06:36 PM
  #71
99Ls1fever's Avatar
Great Cam, People are always making good numbers with this cam. But, I would trust what TSP says and just use 7.4 Rods.
4.10's are calling your name
Originally Posted by web8745
I have a video of the car on the dyno. Just message me and I will send it to you .
Post the Video...
Originally Posted by 06goat
I love my V3. My ls2 made 442.7/389.1 a mustang dyno. I have full bolt-ons
Nice Numbers!!!
Old Jul 16, 2009 | 07:55 PM
  #72
01ssreda4's Avatar
i rode in a V3/exhaust/gears/M6 car, we used to go from 3500 punches and that bitch would fly. Around town it drove like a normal Z28 but at over 3500 that thing could move out.
Old Jul 16, 2009 | 08:32 PM
  #73
m6 drivers... post some vids also
well mine won't be a dd so that should be good with how aggressive this cam is described
Old Jul 16, 2009 | 09:22 PM
  #74
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I really like the Torquer 3 camshaft as a mid-high rpm camshaft. It comes in earlier than the MS4 & makes better mid-range power. That's really important in street car applications.
Remember guys we can guess what pushrods you'll probably need, but it's up the installer to check it & confirm the correct length pushrods are installed! That's the main reason we sell so many pushrod length checkers!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 16, 2009 | 10:24 PM
  #75
99Ls1fever's Avatar
Post A Video!!!!!
Old Jul 17, 2009 | 06:46 PM
  #76
01ssreda4's Avatar
Originally Posted by 99Ls1fever
Post A Video!!!!!
sorry buddy, dont have one. that LS1 took a **** with a connecting rod failure. New motor to replace it is a 6.0 iron block. Hey I do still have the V3 out of that motor (buddys car), its got a tiny nick on it but could be polished out. I already have a tr224 so i dont really need it. Anyone wanna make me an offer???
Old Jul 17, 2009 | 08:27 PM
  #77
99Ls1fever's Avatar
What is the differance in mid and high power between the Torquer 3 Cam and the MS3 Cam? When compared what is the real differance? And why is the MS3 so succesful at the track?
TX Red- Thanks for posting those video's
Old Oct 26, 2009 | 12:06 AM
  #78
Zmg00camaross's Avatar
what kind of torque is this cam in mid range, and any track times with this cam
Old Oct 26, 2009 | 09:12 AM
  #79
LS1-NAVY's Avatar
here is a post i saved when the tv3 was made i was stuck on this cam for about 2 years but then when i finally got a cam i decided to go to a custom cam
"The problem with camshafts is that they're completely subjective. What one thinks is perfect another thinks is too big, too small, too much, not enough, etc. Below are the specs on both camshafts:
Torquer v.2: 232/234, .595"/.598", 112 or 113 LSA standard
Torquer v.3: 231/234, .643"/.598", 111 LSA standard
There were a few goals in designing the T3 cam:
1. better low-end and mid-range compared to the T2
2. more aggressive ramp rate on the intake for better power
3. all around great street/strip cam that is very driveable with a good tune
As you can see, the T3 does have one less degree of duration @ .050" on the intake. It's a more aggressive lobe that ramps up faster vs. the lobe on the T2. It provides greater net lift and allows for quicker opening and closing of the intake valve. Again, whether or not a cam works great in the mid-range is dependent on what you're comparing it to. A smaller cam like our 224R or 228R will provide you with a little more low-end power, but it won't make as much peak power. The T2 camshaft was designed to give customers the ability to make some great power without going too big on cam and without feeling like they didn't go big enough. The T3 was just a revision of the T2. With all other variables of a camshaft held constant, a tighter (i.e. lower numerically) LSA with added advance will help low-end and mid-range power. You can change just these two aspects and completely change the characteristics of how well a camshaft works. The goal is to find the happy medium where the cam works well and makes great power without falling off too quick up top or completely lacking any oomph down low. Some of these issues cannot be 100% solved with adjusting LSA and ICL. A lot of duration relative to the size of the engine is still going to have certain characteristics that go along with it, no matter the LSA or ICL.
The net result is that the T2 and T3 will make comparable power. The T3 is going to provide you with a little more low-end and mid-range power vs. the T2, and it also gives you the capability to use a little more of the flow potential of a good set of ported heads.
Trevor
Texas Speed & Performance"
Old Jan 28, 2011 | 07:27 AM
  #80
ls1jorge's Avatar
Srry to bring up dead thread but this some good information, anybody else has more info about this cam??
