valve train noise
Old Dec 28, 2002 | 06:45 PM
markr02ss's Avatar
Default valve train noise
I have a 2002 ss ls1 . car has about 18,000 miles and on cold start the valve train is extremley noisy . Chev tells me that this normal . Does anyone have imput or simliar condition. thanks
Old Dec 28, 2002 | 09:57 PM
markr02ss's Avatar
Default Re: valve train noise
Well hell o guess i'm the only one with this problem .
Old Dec 28, 2002 | 10:40 PM
LOnSLO's Avatar
Everyone has this problem. Most guys just get tired of answering the same questions over and over. Anyway, some of the noise during cold starts is from the lifters that have bled down while it was sitting. Another part of your problem is piston slap, which is a common problem with LS1s. Do a search on here for piston slap, and you'll find plenty.
Old Dec 28, 2002 | 11:33 PM
markr02ss's Avatar
thanks
Old Dec 28, 2002 | 11:59 PM
Tin Indian's Avatar
Mark...
Does it start making a tapping sound after about a minute or so of idling after a cold start in the morning? Then the noise stops after about 3 minutes or so of continuous idling?
If so, check the fuel vapor purge valve.
It's located right next to the #1 fuel injector (drivers side front). Pop the hood, start the car. As soon as the tapping sound starts, pull the wire connector to the valve. Sound stops... You found the cause of the noise. Pulling the connector for a short period of time while checking the purge valve has never set an SES light.
Ron,
Old Dec 30, 2002 | 06:00 PM
Tin Indian's Avatar
ttt
Old Dec 30, 2002 | 10:10 PM
BLUEBYU's Avatar
Install FRC's....amazing difference.
Old Nov 4, 2004 | 12:57 PM
pewterta's Avatar
what is frc:?
Old Nov 5, 2004 | 03:52 PM
Hawkeye2's Avatar
Fuel Rail Covers - like the Vettes have.
Old Nov 5, 2004 | 04:07 PM
SlyStoner421's Avatar
Hey BlueBYU your car is sweet man...
